speed 3 to the shop
reconbygod12
speed 3 to the shop
Postby reconbygod12 » Thu Oct 07, 2010 9:14
so tomorrow i finally get to pop the speeds cherry and take it into get looked at. something with the fuel is going out causing it to idel at 15 and even hit 16's but in boost im in the 10.3-11.6 range, so im guessing the vaccum line thats on the fuel rail just came loose but knowing bob penkus mazda they wll try to rip me off
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
rush24
Postby rush24 » Thu Oct 07, 2010 9:14
So your AFR's are in the 15-16 range?? Have you checked all the hoses for leaks? What are the mods on the Speed 3??
2007 Black CX7
Apexcone Raptor 6000k HID...
3" DP back Exhaust System
SURE Motor Mount...
[/color]
reconbygod12
i did a boost leak test and i didnt hear damn thing leaking on anything and its ideling at 750 rpms
04 mazda 6s-gone
reconbygod12
i retighened everything and checked all the vaccum hoses, cleaned out the maf sensor and housing on the intake, cleaned the filter, even swapped out recirc kit hose and tried it without the recirc kit and still same reading and sometimes when in boost i can smell fuel
04 mazda 6s-gone
rush24
reconbygod12 wrote:i did a boost leak test and i didnt hear damn thing leaking on anything and its ideling at 750 rpms
Are there any mods on the car?? CAI....SRI....BPV??? Any loose hoses on these items can cause the AFR's to freak out like that.....also check you gas cap....might not be tight...
2007 Black CX7
SURE Motor Mount...
[/color]
reconbygod12
gas cap is tight i mean would it really cause the car to go into lower idle and smell of gas though?
mods:
cobb fmic
cobb turbo inlet
cobb sri
cobb downpipe
cobb exhaust
test pipe
hksqv bov and recirc kit
my accessport
stage shortshifter
and the rest are just for suspension
04 mazda 6s-gone
rush24
reconbygod12 wrote:gas cap is tight i mean would it really cause the car to go into lower idle and smell of gas though?
mods:
cobb fmic
cobb turbo inlet
cobb sri
cobb downpipe
cobb exhaust
test pipe
my accessport
stage shortshifter
Possibly....I had a faulty gas cap on my CX-7 that caused my car to have a rough and low rpm idle....swapped it out and it fixed the issue...there was a TSB for the CX-7's about this....
There are a few things it might be.....your original idea could be one of them....With these engines there are sooooo many things that can cause your issues....
Good luck with the Service Dept.....:D
2007 Black CX7
SURE Motor Mount...
[/color]
Postby tbot » Fri Oct 08, 2010 9:14
what are you're fuel trims like...and also, your afr's in boost are exactly where they're supposed to be...so its just at idle...but yeah look at your fuel trims, that'll tell you if you have a leak or not.
reconbygod12
Postby reconbygod12 » Fri Oct 08, 2010 9:14
stft was at 26 and ltft was at 0 i believe
04 mazda 6s-gone
Postby erod550 » Fri Oct 08, 2010 9:14
26? Yikes. Yea you have a vacuum leak somewhere. Was that at idle?
reconbygod12
yeah tahts my short term fuel trim at idle
04 mazda 6s-gone
vacuum leak...dunno where...but vacuum leak. its going to be post MAF tho since its after the air has been metered, its adding fuel to reach the desired AFR. Since it can't add enough fuel thats why you're running lean at idle as well.
So basically you're getting air into the intake from some source after the MAF...check everything from the MAF all the way thru to your throttle body.
I see a P2187 in your future.
reconbygod12
i have the 2187 already on it came on otherday..it came on before but went away. now its on and sometimes i can smell fuel along with the low idle but boost fine gas mileage is fine jus tthe sensor came on
04 mazda 6s-gone
That's how my car ran too. Fine as long as I was moving, just went way lean at idle because of the vacuum leak. I'd double check the BPV connections especially as that's what was causing my issue.
Users browsing this forum: Google [Bot] and 162 guests
