speed 3 to the shop
- reconbygod12
speed 3 to the shop
so tomorrow i finally get to pop the speeds cherry and take it into get looked at. something with the fuel is going out causing it to idel at 15 and even hit 16's but in boost im in the 10.3-11.6 range, so im guessing the vaccum line thats on the fuel rail just came loose but knowing bob penkus mazda they wll try to rip me off
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
04 mazda 6s-gone
- reconbygod12
- reconbygod12
i retighened everything and checked all the vaccum hoses, cleaned out the maf sensor and housing on the intake, cleaned the filter, even swapped out recirc kit hose and tried it without the recirc kit and still same reading and sometimes when in boost i can smell fuel
04 mazda 6s-gone
04 mazda 6s-gone
- reconbygod12
gas cap is tight i mean would it really cause the car to go into lower idle and smell of gas though?
mods:
cobb fmic
cobb turbo inlet
cobb sri
cobb downpipe
cobb exhaust
test pipe
hksqv bov and recirc kit
my accessport
stage shortshifter
and the rest are just for suspension
mods:
cobb fmic
cobb turbo inlet
cobb sri
cobb downpipe
cobb exhaust
test pipe
my accessport
stage shortshifter
04 mazda 6s-gone
04 mazda 6s-gone
reconbygod12 wrote:gas cap is tight i mean would it really cause the car to go into lower idle and smell of gas though?
mods:
cobb fmic
cobb turbo inlet
cobb sri
cobb downpipe
cobb exhaust
test pipe
my accessport
stage shortshifter
Possibly....I had a faulty gas cap on my CX-7 that caused my car to have a rough and low rpm idle....swapped it out and it fixed the issue...there was a TSB for the CX-7's about this....
There are a few things it might be.....your original idea could be one of them....With these engines there are sooooo many things that can cause your issues....
Good luck with the Service Dept.....
- reconbygod12
26? Yikes. Yea you have a vacuum leak somewhere. Was that at idle?
- reconbygod12
vacuum leak...dunno where...but vacuum leak. its going to be post MAF tho since its after the air has been metered, its adding fuel to reach the desired AFR. Since it can't add enough fuel thats why you're running lean at idle as well.
So basically you're getting air into the intake from some source after the MAF...check everything from the MAF all the way thru to your throttle body.
I see a P2187 in your future.
- reconbygod12
That's how my car ran too. Fine as long as I was moving, just went way lean at idle because of the vacuum leak. I'd double check the BPV connections especially as that's what was causing my issue.
Users browsing this forum: Google [Bot] and 158 guests
