Toubles with TurboXS BOV
deepSpeedMS3
Postby deepSpeedMS3 » Tue Jul 14, 2009 9:14
So i just purchased a Turbo XS Hybrid BOV and I'm having trouble with its sound. I installed according to the directions and they only way to adjust it is to add or substrct washers. It comes with 6 washers and it starts out with too. I am getting a fluttering sound (like a pigeon) i have tried 3-4-5-6 washers and nothing changes. The only other mods i have is a SRI and a Test/race pipe. What do you think? i have heard of people adding up to 10 washers but im alittle weary of that. Should i take some washers out? Let me know what everyone thinks. I know under low RPMs it may flutter...is that normal??? its blows of good at high RPM.
B) deepSpeed MS3 B)
Eclipse
Postby Eclipse » Tue Jul 14, 2009 9:14
flutter at low boost is typical on these cars with a diaphragm style BOV.. Is it good for the car? No.
I am unfamiliar with the TurboXS and the washers, however, sorry.. usually flutter indicates more air pressure in the system than the BOV can relieve. A setting that made the internal spring not as stiff would be the right direction to go
deepSpeedMS3
OCD wrote:flutter at low boost is typical on these cars with a diaphragm style BOV.. Is it good for the car? No.
So maybe less washers is better for it??? what do you think? the more washers the tighter the spring....so take some out?
B) deepSpeed MS3 B)
Postby movovr » Tue Jul 14, 2009 9:14
Sounds like compressor surge.... does it sound like this?
[ame="http://www.youtube.com/watch?v=LZUbo_mNDZM"]YouTube - SR20DET Compressor Surge[/ame]
Eclipse
deepSpeedMS3 wrote:So maybe less washers is better for it??? what do you think? the more washers the tighter the spring....so take some out?
sounds logical to me, again I am unfamiliar with the Turboxs style
Eclipse
movovr wrote:Sounds like compressor surge.... does it sound like this?
^^^^ I LOVE that video... funny how people think the sound is sooo cool
Postby TheNewBlack » Tue Jul 14, 2009 9:14
I ran the TurboXS with 3 washers...it definetely made a difference adding more washers though, the less washers you use the more of a "fluttery sound" you will hear...maybe i could give it a listen sometime. Different BOV's make different sounds....the HKS sounds almost nothing like the TurboXS. Did you have it on your whole road trip?
deepSpeedMS3
i did have it on the road trip. it didnt sound ne thing like that in Minn. but as soon as i got back to CO it started to sound like the video. whats the next step? take it off? let me know
B) deepSpeed MS3 B)
deepSpeedMS3
well i know i just got it .....the problems started after i put the test pipe on.....i guess ill try to sell it to someone. If ne one is looking into it.......ill sell it for $100 OBO to you...let me know....or if theres a way for it to sound better on my car let me know...
B) deepSpeed MS3 B)
Did you buy the BOV from someone on here...I'd ask them if they had the same issue with it.
cyberspeed3
Postby cyberspeed3 » Wed Jul 15, 2009 9:14
TheNewBlack wrote:Did you buy the BOV from someone on here...I'd ask them if they had the same issue with it.
deepspeed3 bought the valve from me. I had no issues. I used 4 washers. It was properly lubed when we installed it. My only mod is the CAI intake.
Not sure what is going on. When he drove off from my house it sounded fine to me. Just like it used to on my car.
deepSpeedMS3
Postby deepSpeedMS3 » Wed Jul 15, 2009 9:14
it did sound fine....all the way up to minesota is was awesome. i put the test pipe on there and it started to have compressor surge. im not sure what the problem is.
B) deepSpeed MS3 B)
Postby movovr » Wed Jul 15, 2009 9:14
Does it flutter under ALL load conditions or just light load? When I had an HKS it would only flutter when shifting under normal driving conditions. At wot it would release just fine and squeel like normal. It happened to me when I put my FMIC + DP on...then I went Synapse and it went away 100%
Synapse FTW
deepSpeedMS3
movovr wrote:Does it flutter under ALL load conditions or just light load? When I had an HKS it would only flutter when shifting under normal driving conditions. At wot it would release just fine and squeel like normal. It happened to me when I put my FMIC + DP on...then I went Synapse and it went away 100%
Synapse FTW
you hit it right on the head.....just like you described. i may switch to synapse soon.
B) deepSpeed MS3 B)
Postby movovr » Thu Jul 16, 2009 9:14
I'm not sure why the HKS valve does this as it is used by many and has a great reputaion. For some reason, it seems to happen now and again based on the mods people have I guess.
Here is a great video that actually shows a side by side comparison of the Synapse and HKS (around 4:56 in).
[ame="http://www.youtube.com/watch?v=MU5Y6d9rh1k"]YouTube - Synchronic Blow Off Valve Turbo S2000[/ame]
