Smoking Turbo? Help!
mOOsE
Postby mOOsE » Fri Apr 24, 2009 9:14
kingtut wrote:Fook, I hate these types of threads. I think this is the first time I've heard about a stock vehicle's turbo smoking... Good luck, hope everything works out in the end-
+1
that pic is shocking :eek:
Whats with these turbo's?
Rich
Postby Rich » Fri Apr 24, 2009 9:14
Mine is smoking as well. Once I'm back to stock, I'll be at the dealer as well.
Postby Stealth01 » Fri Apr 24, 2009 9:14
Rich wrote:Mine is smoking as well. Once I'm back to stock, I'll be at the dealer as well.
At least I don't have to remove any mods to get it fixed, but ten months from now, when the warranty is up....ugh.
Would this be considered covered under the 100K mile drivetrain warranty? Probably not, huh?
mOOsE wrote:+1
I read on the MotorTrend forum that it seems to be a problem with K04 series turbos, except for the smaller ones found in VWs and Audis. SOMEONE should be able to figure out a fix, then!
Postby AIM WO4 » Fri Apr 24, 2009 9:14
OK... I found the thread.
I had to mod my Saab 9-5 in a similar way...
Postby kingtut » Fri Apr 24, 2009 9:14
AIM WO4 wrote:OK... I found the thread.
This link may be helpful too: http://www.mzspd6.com/forum/showthread.php?p=4486661
roninsoldier83
Postby roninsoldier83 » Fri Apr 24, 2009 9:14
I think I may have found the answer you've all been looking for:
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-MS3-005&Category_Code=MS3
^^^That should get rid of the smoke :D
Honestly, I've never been impressed with Hitachi / Borg Warner turbos, don't get me wrong, your turbo seals starting to go isn't even close to major catastrophic failure, but irritating for sure. As far as the major turbo manufacturers go, I always ranked them in the following order:
1. Garrett.
2. Mitsubishi.
3. IHI.
4. Hitachi/Borg Warner.
Seriously though, good luck Stealth!
Mine: 2015 Subaru WRX
Hers: 2013 Subaru WRX
Hopefully this links to the last page of the thread, if not, it's on the last page:)
Thoughts?
http://www.mazdas247.com/forum/showthread.php?t=123691179&page=45
Thanks for all the input, folks! I will read all those and go into the dealer on TUesday prepared!
Rich
Let us know what the dealer says. And I'm going back to stock because I'm selling :)
OK. I'm going to bring all this to the attention of the service techs when I take it to the dealer. I'll e-mail it to one of them I trust and see what he thinks. I'm a mechanical retard, but it makes sense to me that this is not the K04 itself, but our motor, since it doesn't seem to happen with other engines.
Rich
This isn't a standard K04....it was put together for this car. The VW guys are running K03s also, so it's not the same turbo. The Audi guys have used K04s in twin applications I believe (S4?).
Rich wrote:This isn't a standard K04....it was put together for this car. The VW guys are running K03s also, so it's not the same turbo. The Audi guys have used K04s in twin applications I believe (S4?).
Yeah, Audis use the K03's, and many times would be upgraded to the K04--I never heard of any smoking turbos though.
I had the pleasure of riding in this Allroad http://www.rmcb5.com/forums/general-discussion/thanks-randy-and-todd-for-the-work-on-the-dyno-today/ which I about shat myself in....
Did someone mention Audi's in relation to the smoking turbo? Duhhh, nevermind...Stealth mentioned the K04. Regardless, did that link resonate with anyone? ...about the problem not being with the turbo?
kingtut wrote:Yeah, Audis use the K03's, and many times would be upgraded to the K04--I never heard of any smoking turbos though.
Yep. The problem being with the DISI's inability to adequately evacuate oil from the crankcase. I will mention that to Mazda tomorrow, but I don't think they will care much.
Postby kingtut » Sat Apr 25, 2009 9:14
Stealth01 wrote:Yep. The problem being with the DISI's inability to adequately evacuate oil from the crankcase. I will mention that to Mazda tomorrow, but I don't think they will care much.
Cool, just wanted to make sure...there was a lot of reading there! Good luck.
Users browsing this forum: No registered users and 90 guests
