The building block
firestoned
The building block
Postby firestoned » Sat Sep 27, 2008 9:14
So, after much debate, I have decided to move forward with the modifications on my car, rather than letting the car die a stock vehicle.. (of course). This post is not to create drama or arguments between parts or manufacturers, as I have done my research, and feel that these parts are best suited for my application and desires for the car.
Within the next 2 weeks (hopefully) I will receive all my parts, and then schedule one massive install day. These parts include:
DN Performance Stainless Turbo Manifold
CP-E Front Mount Intercooler
PT Performance Super Stock Series Turbo w/34 lb compressor wheel
Reinstall CP-E downpipe and Magnaflow exhaust
Reinstall intake and BOV
Other misc mods include N2MB wotbox, wideband and egt gauges
The latest to arrive sounds like it will be the front mount, so I will be patiently waiting for CP-E to finish production, and ship the bad boy, and then install everything at once. Due to moving the motor so much during the downpipe install, I plan on removing the downpipe/stock exhaust first, then then manifold, then the turbo, and then work backwards on reinstall, and follow up with the front mount last.
Once everything is in, I will update this post, and let you all know when install day is. If anybody wants to watch or help, thats totally fine, just let me know.
Postby Colombia28 » Sun Sep 28, 2008 9:14
Very cool Eric! I'm happy to hear you will be keeping the car and building it up! Can't wait to see the results!
Low Impedance
Postby Low Impedance » Sun Sep 28, 2008 9:14
where do you live?
WWW.RCCDIGIZINE.COM
T-time
Postby T-time » Sun Sep 28, 2008 9:14
nice good luck... pics and dyno when your done i assume
firestoned
Postby firestoned » Sun Sep 28, 2008 9:14
Low Impedance wrote:where do you live?
Firestone, work in Lafayette
cjtherriault wrote:nice good luck... pics and dyno when your done i assume
absolutely, Ill give 'er a week or so, then go dyno
Low Impedance
is that close to the springs?
WWW.RCCDIGIZINE.COM
Postby MazdaTom » Mon Sep 29, 2008 9:14
Low Impedance wrote:is that close to the springs?
http://maps.google.com/maps?hl=en&q=Lafayette%2C%20co&gbv=2&ie=UTF-8&sa=N&tab=il
What's your definition of "close"?
Postby RX-7 Chris » Mon Sep 29, 2008 9:14
Congrads on the setup. it looks great.
Limp it is not very close at all. I think it is about 1:45 away or so.
goldrocket
Postby goldrocket » Mon Sep 29, 2008 9:14
Sounds like it's gonna be pretty nasty! Good luck with the install. Can't wait to see the pics.
Al says
Rich
Postby Rich » Mon Sep 29, 2008 9:14
Eric I'd like to help out on the install. Let me know bud.
bobopud
Postby bobopud » Mon Sep 29, 2008 9:14
I'd help out too if I can make it.
Postby coloskydiver » Mon Sep 29, 2008 9:14
THis is going to be AWESOME!!!!
firestoned
Postby firestoned » Tue Sep 30, 2008 9:14
I am going back and forth on wether or not I should have the manifold ceramic coated or not. DNP says if you have the TMIC, they recommend it, due to extra heatsoak...but with the FMIC, its not an issue. Overall lower temps under the hood would be better, I would think.. but the manifold is simply BEAUTIFUL just how it is, and many people have reported never having an issue without it coated. What do you guys think?
goldrocket
Postby goldrocket » Tue Sep 30, 2008 9:14
Ceramic coating isn't exactly ugly, it looks pretty good, and it lasts. But lower temps under the hood euqals better power and longer engine life.
Al says
Postby RX-7 Chris » Tue Sep 30, 2008 9:14
I say ceramic coating
Users browsing this forum: Bing [Bot] and 56 guests
