CEL code
METHLAB
Postby METHLAB » Tue Jun 10, 2008 9:14
2187.
Discuss.
Postby SpeedRacer » Tue Jun 10, 2008 9:14
ur throwing a 2187 too lean at idle code
METHLAB
The fix?
Nothing? Your running the Cobb SRI I wouldn't worry about it. Just clear it and your fine if it keeps poppin up then i'd worry.
METHLAB
We reset it today, but it tripped again.
fucking weird... Um.... I'm not sure... email christian at cobb? Should be christian@cobbtuning.com or tech@cobbtuning.com
also make sure everythigns tight maybe remove the intake and disassemble and reassemble to make sure its all good
METHLAB
OK, thanks for the input. I'll have a gander tomorrow.
Postby Colombia28 » Tue Jun 10, 2008 9:14
I think, but cant remember correctly that this problem/code is covered by a recent TSB.... i just cant remember.
METHLAB
Postby METHLAB » Wed Jun 11, 2008 9:14
TSB?
Postby Colombia28 » Wed Jun 11, 2008 9:14
Technical Service Bulletin. Issued by Mazda North America. Its kind of like a recall but instead of a full blow recall, they are problems recognized by Mazda and are brought to the attention of dealers, so if a customer comes in with a said problem covered in a certain TSB, the dealer will know how to take care of it.
firestoned
Postby firestoned » Wed Jun 11, 2008 9:14
andrew, you are right, the P2177 and P2187 are both related to the recent TSB on the fuel pumps. Let Mazda know whats going on, they will put the pump through a series of tests, and determine if you are eligible for the new fuel pump..
METHLAB
Word up G!
firestoned
Shane, found this info on another foum too:
Hi all,
The CEL was on last week and dealer told me they replaced "Purge Solenoid Valve" for the error code p0171/p0172/p0441/p0442/p0455/p0456/p2178/p2187/p2188. And now my car is running fine.
METHLAB
Awesome sauce. I'll call them shortly.
Users browsing this forum: Google [Bot] and 118 guests
