Another FD in the area
JTurton7
Postby JTurton7 » Mon Sep 01, 2014 9:14
wasn't planning on it. I was thinking more of ducting some air flow to that area to keep the turbo cool.
JTurton7
Postby JTurton7 » Tue Sep 02, 2014 9:14
Intercooler pipes almost done, just need to go get the bov hole welded shut. I ran out of cool tape :(
Postby speedjunkie » Tue Sep 02, 2014 9:14
Ooh I like the hardlines to the turbo. This is something I've wanted to do as well. Did that come with the kit?
JTurton7
yeah that is what came with the kit
JTurton7
When K&N says the total length is 5 inches they apparently mean that the filter part is 5 inches and the mounting area is like a half an inch more... It would have fit perfectly if total length of 5 inches actually meant that the total length was 5 inches.... ughhhhhh
Wait, looking at those hardlines again, where is that coolant line going? lol
Also, on the K&N website, did it show that length includes the mounting portion or just the filter? There is usually a guide on their site that shows the dimensions of a, b, c, etc.
JTurton7
Postby JTurton7 » Wed Sep 03, 2014 9:14
it goes to the upper port usually used for the throttle body thermowax thing.
On their website it just says height:5 inches :/
http://www.knfilters.com/search/product.aspx?prod=ru-2520
lOOkatme
Postby lOOkatme » Wed Sep 03, 2014 9:14
Jason, I have a shorty filter, I can go measure it and would be willing to let you have it if you want. I bet it will fit. (made by K&N).
Postby speedjunkie » Wed Sep 03, 2014 9:14
Hmmm, I wonder why they chose to draw coolant from there instead of a cooler place, unless that's where it's dumping into.
You do know on the EFR to hook up the feed coolant line on the bottom port and the exit on the top port, right?
FDEEZ
Postby FDEEZ » Wed Sep 03, 2014 9:14
JTurton7 wrote:When K&N says the total length is 5 inches they apparently mean that the filter part is 5 inches and the mounting area is like a half an inch more... It would have fit perfectly if total length of 5 inches actually meant that the total length was 5 inches.... ughhhhhh
Any way you can bend that bracket into a "U" shape for additional clearance for the filter?
JTurton7
Postby JTurton7 » Fri Sep 12, 2014 9:14
All together and running!
Proof!
FDEEZ
Postby FDEEZ » Fri Sep 12, 2014 9:14
Congrats! Another FD back on the road :-)
Postby speedjunkie » Fri Sep 12, 2014 9:14
Sweet! Congrats!
JTurton7
Postby JTurton7 » Tue Sep 16, 2014 9:14
This thing spools sooooo fast. Its hard to keep it out of boost haha
Saul_Good
Postby Saul_Good » Tue Sep 16, 2014 9:14
Real sexy! Can't wait to see it in person.
