New FD in Town!
Postby speedjunkie » Mon Mar 11, 2013 9:14
Yeah they needed to shut the outlet on the bottom of the radiator and put it at the top as well. That's cutting corners doing it the way they did it and I'm surprised, Defined usually is on top of things.
Postby VRx8 » Tue Mar 12, 2013 9:14
I got quoted $240 for the undertray. $80 in material and $160 for cutting. He said he can cut the under tray in like 5 minutes but the minimum is $160 Hr. All I have to pay is material up to an hour.
Postby VRx8 » Wed Mar 13, 2013 9:14
Installed the Diff today. Took me 5 minutes :D
Highly recommend this little tranny jack. Harbor Freight $70 bucks so worth it.
I'll be installing a PFS Girdle along with a Banzai Brace. Some people say It can't be done but will see :D
Postby speedjunkie » Thu Mar 14, 2013 9:14
Yep, that tranny jack is the ish. Makes installing the tranny so much easier than trying to lift and slide it in by yourself LOL.
Oh yeah, I was cleaning the garage last night and realized I still have your flywheel stopper (long piece of angle iron) lol.
Postby VRx8 » Sat Mar 16, 2013 9:14
speedjunkie wrote:Yep, that tranny jack is the ish. Makes installing the tranny so much easier than trying to lift and slide it in by yourself LOL.
I was looking for it the other day lol.
Rear end is finally done... :187fe223:
PFS Girdle Installed along with the Banzai Diff Brace, some people @ 7club were saying that It couldn't be done lol. Well it just requires a simple modification.
You can see where I cut the Girdle
Also installed new TC Sportsline trailing arms
Postby chickenwafer » Sat Mar 16, 2013 9:14
Noice!!! That diff is going NOWHERE!
Does PFS still make that girdle? That thing looks legit.
Yeah but i would get the one that Eric has. I did it this way because I got this girdle fairly cheap as well as the banzai brace
Postby VRx8 » Sun Apr 14, 2013 9:14
Took the FD for a cruise with the new gears and wow I have a 5th gear that's worth a damn. Car felt more eager begin for more gas. I'm very happy with the upgrade and is worth the trouble.
I was actually data logging and tuning as I went. Gor the cruising AFR's where I wanted. Tried to go into boost but I was going lean, I need to start the transition a little bit sooner. Right now the primaries are going as far as 6 psi.
It averaged 11 MPG Horrible yes but AFR's where kind of rich around 13's. Also not using decel fuel cut.
Postby chickenwafer » Tue Apr 16, 2013 9:14
Sounds great man!
Postby VRx8 » Sat Apr 26, 2014 9:14
Update is been a long time well that Diff above is long gone. Cracked the case even though i was using all them braces. Turbo2 LSD didnt even knew what happened.
Here is my car finally got it working fine after month of troubleshooting, found out after going Direct Fire ignition I had the spark plug wires on the wrong location LOL. What a noob. Dno it at 463whp@18psi E85
http://youtu.be/LEDHkQ49Gl4
This thing is hauling ###. this pass was at 18-19psi
I think its got a low 11 or even a High 10 second pass with a little bit more boost.
Currently under the knife for a 8.8 Diff upgrade and fuel system upgrade.
Pics:
Diff 8.8
Major parts:
4x2200cc, haltech ps1000, aem smart coils, direct fire, 8an feed 6an return, CORN and More CORN!! E85 is bad ###. t72 turbonetics .69 A/R too small! Ebay manifold.
Postby speedjunkie » Sat Apr 26, 2014 9:14
That's awesome man! Did you run stainless braided lines all the way to the front? Or did you do a hard line? Also, do you have trouble starting the car on E85? I've heard it can be difficult to start.
Ss brsided teflon lines from frozenboost.com all the way
E85 is hard to start in cold temperatures. 60f and above starts right up.
boosted12a
Postby boosted12a » Sun Apr 27, 2014 9:14
looking good bro!!!
FDEEZ
Postby FDEEZ » Sun Apr 27, 2014 9:14
What tire were you running that you broke your diff? Also, what rpm did you launch at?
Users browsing this forum: No registered users and 101 guests
