New FD in Town!
speedjunkie wrote:Yep, that tranny jack is the ish. Makes installing the tranny so much easier than trying to lift and slide it in by yourself LOL.
Oh yeah, I was cleaning the garage last night and realized I still have your flywheel stopper (long piece of angle iron) lol.
I was looking for it the other day lol.
Rear end is finally done...
PFS Girdle Installed along with the Banzai Diff Brace, some people @ 7club were saying that It couldn't be done lol. Well it just requires a simple modification.
You can see where I cut the Girdle
Also installed new TC Sportsline trailing arms
Took the FD for a cruise with the new gears and wow I have a 5th gear that's worth a damn. Car felt more eager begin for more gas. I'm very happy with the upgrade and is worth the trouble.
I was actually data logging and tuning as I went. Gor the cruising AFR's where I wanted. Tried to go into boost but I was going lean, I need to start the transition a little bit sooner. Right now the primaries are going as far as 6 psi.
It averaged 11 MPG Horrible yes but AFR's where kind of rich around 13's. Also not using decel fuel cut.
Update is been a long time well that Diff above is long gone. Cracked the case even though i was using all them braces. Turbo2 LSD didnt even knew what happened.
Here is my car finally got it working fine after month of troubleshooting, found out after going Direct Fire ignition I had the spark plug wires on the wrong location LOL. What a noob. Dno it at 463whp@18psi E85
http://youtu.be/LEDHkQ49Gl4
This thing is hauling ###. this pass was at 18-19psi
I think its got a low 11 or even a High 10 second pass with a little bit more boost.
Currently under the knife for a 8.8 Diff upgrade and fuel system upgrade.
Pics:
Diff 8.8
Major parts:
4x2200cc, haltech ps1000, aem smart coils, direct fire, 8an feed 6an return, CORN and More CORN!! E85 is bad ###. t72 turbonetics .69 A/R too small! Ebay manifold.
Pics:
Diff 8.8
Major parts:
- boosted12a
Users browsing this forum: No registered users and 126 guests
