Newb Drift Build
azureseele
Newb Drift Build
Postby azureseele » Tue Apr 22, 2014 9:14
Decided to get serious with the car and do some vital replacements to get the car going sideways. Since 2011 and present i've dabbled with some modifications here and there: ss oil lines, mech omp removal, godspeed radiator, and electric fan from some van.
Thinking I could get the car drift ready in 6 days for an upcoming drift clinic...
Who the hell was I kidding?!
Then came in the new the parts
And then problems began piling up...
Seriously, it was like they welded this sh*t on!
Cleaned up the rear harness because I couldn't get anything else accomplished.
And so I'm going to get some dtss eliminators presssed in at a shop because, look at my garage, no space for a nice fancy press. And only on one hub too, why? Because the left one is still stuck on the axle like a mf.
Any suggestions on how to get it off? i've pounded on it with a mallet, used a 3 jaw puller, plasted it with pb. Won't even budge like a fat man on a couch watching the Food Channel. *le sigh*
azureseele
Oh, and I like to do photography. so hit me up if you want to do a photoshoot because they're aren't enough photos of CO rx7's.
lablue96
Postby lablue96 » Tue Apr 22, 2014 9:14
Nice picture with the sunset in the backgroung
Postby Shadowden » Tue Apr 22, 2014 9:14
Are you trying to take te axle nut off with an impact wrench? Is it a high powered quality one? Should zip the thing right off.
Where did your car live prior to Colorado? One thing that is really nice about the cars I have had since living here is that I haven't had any issue with stripped bolts and such.
Quite the contrary in Pennsylvania.
Postby erod550 » Tue Apr 22, 2014 9:14
I hate it when the damn nitrile gloves rip and then you can't get a new pair on cause you're hands are all sweaty. Argh, lol.
Postby I`m Batman » Tue Apr 22, 2014 9:14
Looks like a lot of work. Can't wait to see the finished product.
azureseele
Shadowden wrote:Are you trying to take te axle nut off with an impact wrench? Is it a high powered quality one? Should zip the thing right off.
Lived in Seattle, Washington for a few years and spent the rest of its days in Colorado, purchased it from the original owner.
The right rear hub slid off like butter
It's the left side that's giving me such a hard time, won't even budge...any suggestions?
I'd try a really long pry bar. Sometimes axles can be stubborn, especially if any kind of corrosion built up in the splines.
Postby RX-7 Chris » Wed Apr 23, 2014 9:14
Have you tried some PB Blaster over night?
How about heat?
Postby Shadowden » Wed Apr 23, 2014 9:14
RX-7 Chris wrote:Have you tried some PB Blaster over night?
How about heat?
I thought I read he soaked it in PB blaster.
Heat is a great suggestion. You've probably done this job before.
azureseele
Postby azureseele » Thu May 01, 2014 9:14
well, finally got the hub off, had to take the axle off and bring it to a shop
apparently the hub was rusted like crazy onto the axle
did some cleaning and polishing...
What should i paint the interior? Debating on white or some dark color like gunmetal or black?
Postby Shadowden » Fri May 02, 2014 9:14
The gunmetal will be a two stage paint project. Pretty sure you will need to lay a silver or chrome base, then cover it with the translucent black. I think it would look good and be unique.
azureseele
Postby azureseele » Mon May 05, 2014 9:14
thanks for the input shadowden! I need to do some more research before i can decide. Anyone know how to remove the downpipe without taking the engine out? I have no idea how to get to the turbo side bolts.
