My New Toy
I don't have the welded pictures yet but here are pre welded fitment pictures.
We worked on the car last night.
I stripped the front driver's side fender (red). It was a junk yard fender and we tried to just give it a sanding before primer but the quality of the paint used on it was very poor so I had to completely strip it. I also worked on sanding the primed front cowl guide coat so we could find dents that needed to be filled.
This just came in the mail:
http://www.re-speed.com/index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=56&virtuemart_category_id=22&Itemid=18
Energy Suspension, HYPER-FLEX SYSTEM graphite impregnated black bushings Complete Master Bushing Set.
Kit includes:
Kit includes:
- Front control arm bushing kit.
- Front sway bar end links.
- Front sway bar mounting bushing kit.
- Front stay rod bushing kit.
- Rear control arm bushing kit.
- Watts linkage kit.
- Rear sway bar end links.
- Rear sway bar mounting bushing kit.
Almost ready to race now.......
Still have your helmet?
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
2 Fords 29 & 2000.
99 BMW 328i
I do still have the helmet.
Here are some pics of the welding progress as of Saturday:
Here is a pic of where the frame rail had to be opened up to weld inside:
the windshield was removed yesterday so it could be replaced and they found some rust that needs to be repaired before the new one is put in. He was going to fix that last night. He also worked some more on the front cowl and did some welding on the front. The car is now on the lift so he can weld underneath.
On saturday I replaced the throwout bearing and also installed the highflow cat. The project turned from a 2 hour job to an entire day because the tranny jack died. We ended up having to rebuild it. This was one of those tranny jacks for the lift.
I haven't gotten any pics of the cat installed yet.
Huzer wrote:Did a stud break off on the passenger side strut??
yes that happened at the alignment shop before the painting started. I have another strut mounting block I need to install.
We made more progress last night. Finally stuff is actually happening.
Filling is nearly done on the front end. I removed more components from the engine bay to prepair for paint. I also did cleaning and sanding.
The cat installed:
front end as of last night:
Users browsing this forum: Bing [Bot] and 59 guests
