My new Rx7 R1
VRx8 wrote:That gauge is inaccurate get an aftermarket one. Or maybe getting a new sensor. I say don't worry but get an aftermarket one ASAP. Same with water temp gauge.
cool i will, and i have my water temp on my pfc so im good there, do you think its safe to get on it hard before i get one? i mean i have been at events and what not but now that i know it could be a problem do you think i should wait
VRx8 wrote:Prosport
oh word! thanks man!
also, do you really think i should wait til i get the gauge and check it, i mean its kind of been like this for as long as i can remeber really, but it does go up to like normal pressure under load, is that weird that it works under load but so low at idle? i only ask cause there is a drift event tomorrow i was really looking forward to, but if you think i really should wait i will cause id much rather be safe then sorry
chickenwafer wrote:A bad sensor connection more than likely. Pull the tab off the pressure sensor in the rear iron and clean it with some sandpaper. The OEM gauge isn't always accurate, which is why Eduardo recommended replacing it with an aftermarket gauge.
Ok thanks I'll try that, and yea i have one coming as we speak! Lol
