New FD in Town!
Postby VRx8 » Fri Mar 30, 2012 9:14
boosted12a wrote:donde hicieron eso? se ve bien!!!!
lo hicieron en front range polishing
eliminster
Postby eliminster » Fri Mar 30, 2012 9:14
polished parts look good hope you get your ride together soon so we can all go for a cruise sometime.
87 red rx7
running 13b re cosmo motor
03 yellow wrx
yes it is a stock color
00 black s10 zr2
I'm down with that, I haven't done a cruise in a long time.
Got a decent amount of work done today! Installed the intake manifolds, fixed and organized engine harness, installed the v mount kit also made the hot side charge pipe.
Pic of the 3" charge pipe
And my grounding kit
Postby speedjunkie » Sat Mar 31, 2012 9:14
Did you make that grounding kit? I've never seen that one.
SO MUCH BLING! lol Looks good man.
I'm soooo down for that cruise too, especially after tonight haha.
Rx7boy719
Postby Rx7boy719 » Sat Mar 31, 2012 9:14
speedjunkie wrote:Did you make that grounding kit? I've never seen that one.
Yea lol..... Hopefully next weekend, but the engine looks awesome can't wait to see it in person.....
Postby VRx8 » Sat Mar 31, 2012 9:14
Thanks Eric, that grounding kit a bought it from ebay fairly cheap. Is an "HKS" kit.
Postby chickenwafer » Sat Mar 31, 2012 9:14
Looking awesome man
I was going to start the car today but I ran to a little problem! One of the AN fitting on the secondary fuel rail won't stop leaking! Pissed me off. Tried everything I could think off, new fitting, teflon tape, no teflon tape, new hose. I checked the male end on the rail and it doesn't look nicked or damaged. Im going to order new fittings and some kind of thread sealant.
Also made a hasty bracket for the breather tank and the AST. Right now im waiting on a 6AN bung for the oil filler neck, so I can drop off the elbow, charge pipe and filler neck at the welder.
edit: After some research online found out that Summit 90 Degree fittings are prone to leak, supposedly the fix to this is buying Aeroquip fittings, so i order them and some conical seals.
Postby speedjunkie » Sun Apr 01, 2012 9:14
VRx8 wrote:Thanks Eric, that grounding kit a bought it from ebay fairly cheap. Is an "HKS" kit.
I like how you put quotations around HKS lol.
VRx8 wrote:edit: After some research online found out that Summit 90 Degree fittings are prone to leak, supposedly the fix to this is buying Aeroquip fittings, so i order them and some conical seals.
FUUUUUUUUUUU!!!!!!!!!!!!!
Postby chickenwafer » Mon Apr 02, 2012 9:14
Wow, good thing I didn't do all Summit fittings as I had planned. That sucks.
Postby speedjunkie » Mon Apr 02, 2012 9:14
chickenwafer wrote:Wow, good thing I didn't do all Summit fittings as I had planned. That sucks.
REALLY?! I believe SOMEONE told me Summit had good fittings! I wonder who that could be. What a delta mike LOL!
Postby chickenwafer » Tue Apr 03, 2012 9:14
Pretty sure I told you eBay fittings were good. Or Summit fittings. I say a lot of things haha
Postby VRx8 » Tue Apr 03, 2012 9:14
Lol I mean they weren't leaking before, it was after I replaced the LIM that i had to take the fuel lines off.
Postby speedjunkie » Tue Apr 03, 2012 9:14
chickenwafer wrote:Pretty sure I told you eBay fittings were good. Or Summit fittings. I say a lot of things haha
Yeah you told me Summit fittings were good, that's why I bought them LOL.
VRx8 wrote:Lol I mean they weren't leaking before, it was after I replaced the LIM that i had to take the fuel lines off.
Well I don't think mine are leaking, but they're just used for the boost and vent lines on the wastegates, boost control valve solenoid, etc, so I won't really know until I boost. Should be fine though...I hope lol.
Either way, it's awesome you're getting finished too. We're gonna have a good size crew this summer!
