New FD in Town!
boosted12a
Postby boosted12a » Sun Dec 18, 2011 9:14
haha let me know when you are ready to race my 12a
Postby VRx8 » Sun Dec 18, 2011 9:14
I'll let you know make sure you bring pen and paper so you can write down my license plate number lol. Tas peldio !
Postby chickenwafer » Sun Dec 18, 2011 9:14
VRx8 wrote:Msd Coils are quite expensive a MSD ignition setup is not cheap at all LOL
Actually the MSD 6AL-2 is only $252 bucks http://www.summitracing.com/parts/MSD-6421/
And it can use OEM coils no problem. But you have to wire everything, which sucks haha.
Now you got me thinking about a MSD setup lol. The MSD coils are about 50 bucks a piece your need 2x8207 and a twin tower for the trailing. Now do you need a separate box for the trailing? or the 6AL-2 is able to provide for the trailing and leading? I like the idea of a 2 step, I'll like to do some drag racing and 2 step is a must.
The leading ignition does all the work, trailing is just for clean up. If you wanted to run an ignition amp on the trailer you would actually need 2 extra MSD boxes, so a total of 3. Some people do this but unless you're running pure methanol/alcohol it's not needed. A single box is good enough for over 700rwhp on a 2-rotor, just boosting the leading.
You need a relay (nothing special, just a cheap 5-pin relay from AutoZone or wherever) so when you step on the clutch, it cuts power/ignition to the trailing coils. You DON'T want the 2-step on the trialing coils, or you could detonate. So by using the relay with the clutch switch, it deactivates the trailing coils and the 2-step works on the leading coils.
Here is how it would be wired; ignore the "crane" label on the ignition box. The MSD is wired up the same, wire colors may be different. Also, not pictured in the wiring diagram I made is a switch on the clutch switch wire coming out of the relay. You should put a switch on this so you can deactivate the 2-step for two reasons; first, just to turn it off. Secondly, since you have to push in the clutch to start the car, this would normally kill your trailing ignition, which makes a cold start more difficult. So the switch makes it easier to start.
JTurton7
Postby JTurton7 » Sun Dec 18, 2011 9:14
Just do an ignition cut rev limiter for drag launches hahah. Dont they just dump the clutch at the limiter anyway?
I want this (its a 13b in a 240 btw) WARNING LOUD VIDEO
[ame="http://www.youtube.com/watch?v=vHDX78z5V6s"]s14-burnout - YouTube[/ame]
boosted12a
Postby boosted12a » Mon Dec 19, 2011 9:14
VRx8 wrote:I'll let you know make sure you bring pen and paper so you can write down my license plate number lol. Tas peldio !
hahaha my SA (FD grandpa) is going to sent your FD back to school :D
Postby Shadowden » Mon Dec 19, 2011 9:14
JTurton7 wrote:Just do an ignition cut rev limiter for drag launches hahah. Dont they just dump the clutch at the limiter anyway?
What is the machine gun type noise being made? Is that coming from the engine?
Postby VRx8 » Mon Dec 19, 2011 9:14
^^^ Redline with no exhaust
JTurton7
Postby JTurton7 » Mon Dec 19, 2011 9:14
Full ignition cut rev limiter doesnt cut fuel at all so all the unburnt fuel just explodes in the exhaust.
seems not so smart an idea to me...but I don't know a whole lot.
JTurton7
Postby JTurton7 » Tue Dec 20, 2011 9:14
some say its mildly safer due to... well zero chance of having a random lean condition and getting detonation. Down side is melting your cheap china turbo haha.
Postby speedjunkie » Tue Dec 20, 2011 9:14
If it's a cheap Chinese turbo, it needs to be melted anyway haha.
Postby chickenwafer » Thu Dec 22, 2011 9:14
Eduardo, do you remember the size of the fittings you used to loop the line on the power steering rack?
Postby VRx8 » Thu Dec 22, 2011 9:14
You have to modify your own OEM lines.
Users browsing this forum: Baidu [Spider] and 49 guests
