Another FD in the area
eliminster
eliminster
I usually recommend keeping the 550cc side feed primaries to maintain an acceptable idle. You really only need to replace them if you're looking for major horsepower (600+) or an E85 setup. Plus, it saves you a good chunk of money.
CJ doesn't sell the secondary rail alone that I know of, so for that reason I would vote KG Parts. If you're redoing the whole fuel system and want to replace the primary rail for whatever reason, then CJ rails are nice.
Really, they are just milled pieces of aluminum, not really a performance difference between the two (except the CJ rails have the Tee fitting on them to save you a fitting...)
eliminster
let me just say that 1000 cc primaries and a large street port makes your car idle almost like its a bridgeport, which is nice sometimes then I think of all the fuel I am burning while idling and I wish I had gone with smaller primaries.
87 red rx7
running 13b re cosmo motor
03 yellow wrx
yes it is a stock color
00 black s10 zr2
03 yellow wrx
00 black s10 zr2
I like the CJ rails just because I feel they mount a little more securely.
eliminster hit the nail on the head. I had 1000cc primaries and a large street port before going with 725cc ID primaries and my car used to sound like a bridgeport quite often. I loved the sound, but it only idled that way because it was drowning in fuel.
Haha, alright Eric.
And to JTurton, you can send the 550's out to get cleaned, check out http://witchhunter.com/
Then they are as good as new.
^That is true, same thing happened to a friend of mine. Witch Hunter even recommends using the cleaned injectors within a few days of getting them back to avoid them sticking.
You can also "pulse" the injectors with a car battery and two wires, simply touch them terminals on the injectors quickly to pulse the driver and make sure they work.
