Another FD in the area
eliminster
Postby eliminster » Tue Nov 29, 2011 9:14
I'm on the forum just don't get around to the meets due to work, but welcome to the springs jturton.
87 red rx7
running 13b re cosmo motor
03 yellow wrx
yes it is a stock color
00 black s10 zr2
eliminster
Also if you were driving on academy around 1:20 I think I may have seen your car as I pulled off of I 25 onto academy
87 red rx7
03 yellow wrx
00 black s10 zr2
JTurton7
Postby JTurton7 » Tue Nov 29, 2011 9:14
i drove from base down powers to get some delicious food at monicas at like 12ish haha
JTurton7
Im debating between KG parts or CJ motorsports for fuel rails.
Postby chickenwafer » Tue Nov 29, 2011 9:14
I usually recommend keeping the 550cc side feed primaries to maintain an acceptable idle. You really only need to replace them if you're looking for major horsepower (600+) or an E85 setup. Plus, it saves you a good chunk of money.
CJ doesn't sell the secondary rail alone that I know of, so for that reason I would vote KG Parts. If you're redoing the whole fuel system and want to replace the primary rail for whatever reason, then CJ rails are nice.
Really, they are just milled pieces of aluminum, not really a performance difference between the two (except the CJ rails have the Tee fitting on them to save you a fitting...)
JTurton7
the biggest reason why im thinking i should be going with cj rails and 1000/2000 or 750/2000 is because my stock 550's are 18 years old. I feel like this is a reliability upgrade.
eliminster
let me just say that 1000 cc primaries and a large street port makes your car idle almost like its a bridgeport, which is nice sometimes then I think of all the fuel I am burning while idling and I wish I had gone with smaller primaries.
87 red rx7
03 yellow wrx
00 black s10 zr2
Postby speedjunkie » Wed Nov 30, 2011 9:14
I like the CJ rails just because I feel they mount a little more securely.
eliminster hit the nail on the head. I had 1000cc primaries and a large street port before going with 725cc ID primaries and my car used to sound like a bridgeport quite often. I loved the sound, but it only idled that way because it was drowning in fuel.
Postby VRx8 » Wed Nov 30, 2011 9:14
Well i have 725cc injector on mine and still get the brap brap. They are not 100% tuned; i think 725 u get the best of both world, you can get the car to idle right and its got the extra fuel for more power.
Well I'm going to get Dave to get my brap brap back as well...I miss it lol.
Postby chickenwafer » Thu Dec 01, 2011 9:14
Haha, alright Eric.
And to JTurton, you can send the 550's out to get cleaned, check out http://witchhunter.com/
Then they are as good as new.
JTurton7
Postby JTurton7 » Thu Dec 01, 2011 9:14
I had all my injectors cleaned by them like 5 years ago I think, It was a while ago.
Postby speedjunkie » Thu Dec 01, 2011 9:14
One thing though, once you get them cleaned, make sure you put them in right away and get some fuel through them. I got some injectors from someone that had been cleaned but had been sitting around for a while, and they were stuck closed by the time I got them and tried to use them.
^That is true, same thing happened to a friend of mine. Witch Hunter even recommends using the cleaned injectors within a few days of getting them back to avoid them sticking.
You can also "pulse" the injectors with a car battery and two wires, simply touch them terminals on the injectors quickly to pulse the driver and make sure they work.
JTurton7
anyone around here running e-85?
