Club Install Weekend Apr 16th and 17th
ecam8000
Postby ecam8000 » Mon Apr 04, 2011 9:14
No sign up needed. But it would help to know who will be at the thrash and on which days. All are welcome (rookies that want to learn please plan to come). We should be able to have three cars "inside" at a time and room for more on the driveway (if the weather is nice).
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
ecam8000
Milcre wrote:I have not met anyone here in person but would like to and I need to put in a turbo xs dp and rp in my speed 3. Does this project sound doable for this event?
I need to know more (or have a translator - xp, dp & rp? - I come from a pre texting generation) but we should be able to work on that.
Eric
2 Fords 29 & 2000.
99 BMW 328i
Postby bellalyssa » Mon Apr 04, 2011 9:14
christi wrote:So, id like to go if it's not too late to sign up or whatever.
Depending if I want to do the 3's t-stat replacement then or the rx-7's water pump or something. I still need to find the thermo sensor for the one on the back of the engine but noone carries it :/
edit:
I'll go either way to have fun :) and learn!
... I can't be there that Saturday, unless you guys are doing things *after* say like, 830PM. I work until 6 that night and won't be back in springs til 7, and I can get to denver around 8-830. If not, I'll be there sunday.
Christi, I can order parts for you. Just get me the part number and I'll get it sent to me. It's waaaaaay cheaper through me.
I'll be there Saturday but not Sunday. If my skid plates aren't on by then, that's all I'll need to do.
Postby speedjunkie » Mon Apr 04, 2011 9:14
ecam8000 wrote:I need to know more (or have a translator - xp, dp & rp? - I come from a pre texting generation) but we should be able to work on that.
I believe Turbo XS is the company, DP should be downpipe and RP could be rear pipe? I think lol.
Twisted_grip
Postby Twisted_grip » Mon Apr 04, 2011 9:14
Hmm... I might stop by before going to work on saturday Ecam. Maybe a good time to meet everyone and introduce myself!
Postby erod550 » Mon Apr 04, 2011 9:14
RP = race pipe or test pipe. Easiest install there is, 15 min tops. Downpipe however, is much more involved.
Postby Number2 » Mon Apr 04, 2011 9:14
I've installed a Turbo XS downpipe...It's tricky, esp getting the new one back in.
Can you check the flange for the Race-pipe > cat-back exhaust connection See if it's a flat diamond shape or if it's a designed for a donut gasket. Because if memory serves, stock uses donut gaskets throughout and the turbo xs does not.
Otherwise you will have an exhaust leak. Also, you will need a tune for the downpipe, or you'll be experiencing serious load cut.
christi
Postby christi » Mon Apr 04, 2011 9:14
Okay I cannot get off Saturday so I'll be there sunday. I have some rotors that need to be put on the 7 that I can have done if I fix my water pump leak, to be able to drive up there. However my brakes on the 7 are I'm excellent condition should I just not worry, and come for a learning experience?
Also how far can 20% left of rear brake pads last? (in the 3)
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
My rear pads were replaced for the first time at 100k. I think you're good.
christi
Also lyssa il send you a fb msg for parts
13B n/a Street Port
Goopy performance
2005 Mazda 3
ecam8000
[quote="christi"]
Do some math, how many miles on those rears....? Do those pads have the squeal clips, they'll make noise before they do damage.
Eric
2 Fords 29 & 2000.
99 BMW 328i
christi
ecam8000 wrote:Do some math, how many miles on those rears....? Do those pads have the squeal clips, they'll make noise before they do damage.
Math is totally not my friend =P
On a serious note, they're the original brake pads...64k miles on them.
I justn find it weird that the best have worn down *faster* than the fronts... in a fwd car .
13B n/a Street Port
Goopy performance
2005 Mazda 3
ecam8000
Postby ecam8000 » Tue Apr 05, 2011 9:14
christi wrote:Math is totally not my friend =P
Then check them again in 5000 miles, plan to replace them at 10K. Or bring a set along and we can swap them on that Sunday. Traditionally front brakes do most of the work in cars (weight shift and such) The front brakes are also larger diameter and larger pad surface. A highway driven car will see the rear wearing faster or more even with the fronts. Lowered and "sport" cars will throw that balance off too.
Porsche's 911 has always been a car with pretty much the same brakes and wear front and rear.
It's what we drive and how we drive them. It's not weird, it is just different from the rest of the world.
Eric
2 Fords 29 & 2000.
99 BMW 328i
Milcre
Turbo XS Stealthback exhaust
Postby Milcre » Tue Apr 05, 2011 9:14
One of the websites states the following which I assume means it is supposed to match up right:
This stealthback exhaust for the Mazdaspeed3 includes an adapter plate for your OEM catback exhaust or will mate to any aftermarket catback system to as part of a full turboback exhaust. Kit includes OEM adapter plate, gaskets and hardware.
I also plan on getting an Accessport soon to help with tune but do I need to have it tuned at a shop?
