Ron's Monster Miata Build
ecam8000
Postby ecam8000 » Wed Feb 16, 2011 9:14
Cost will depend on how much you are able to do yourself. I could drop any engine on (or in, if you have a convertible) your car for minimal money! If you want it to run (or fit) that is different. B)
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
Postby coloskydiver » Fri Feb 18, 2011 9:14
Home sweet home. I am a little scared because this thing sits low. Took 20 minutes to get on the trailer and 30 minutes to get it off.
rush24
Postby rush24 » Fri Feb 18, 2011 9:14
Looks good.....
2007 Black CX7
Apexcone Raptor 6000k HID...
3" DP back Exhaust System
SURE Motor Mount...
[/color]
Postby RX-7 Chris » Fri Feb 18, 2011 9:14
nice to have it home.
Postby GR-8 » Fri Feb 18, 2011 9:14
It's looking good Ron! :cool::9b5bde:
Postby coloskydiver » Mon Feb 21, 2011 9:14
Now that the car is running and somewhat drivable, it has give me a chance to get out and play with the GoPro. Here is something I through together in just a few minutes. Also some pics.
[ame="http://www.youtube.com/watch?v=ty8ihpDNz1M"]YouTube - Monster Mix[/ame]
Postby Learjet45 » Mon Feb 21, 2011 9:14
Looking beautiful! Enjoy responsibly! I'm extremely jealous right now :p
MazdaSweet3
Postby MazdaSweet3 » Mon Feb 21, 2011 9:14
*drools*
Cp-e Nano SRI
Cp-e CBE
SU rear engine mount
SU test pipe
Cobb turbo inlet
Cobb Access Port
Turbosmart BPV
Postby erod550 » Mon Feb 21, 2011 9:14
Nice video, but turn off the music on the next one so we can hear that thing growl. Also, do you plan on putting some mesh or something in the front bumper to hide the radiator fans?
Love the stance on that thing. Mine has the stock springs back on it and looks like a monster truck now. :(
memphis
Postby memphis » Mon Feb 21, 2011 9:14
so when are you taking it to the track to see what it really can do :P... good job buddy!!
Postby coloskydiver » Tue Feb 22, 2011 9:14
Thanks for all th comments. I still have a bit of work to do still but at least I have the pleasure to go out and drive it. There is still a lot of trouble shooting and issues that need to be adressed as the pop up. Side skirts/ spoiler need installed, stearing wheel needs aligned, rear end needes to come up to match the front, and am now having issues with changing gears and geting in reverse. Hopfully I should be able to have all the bugs worked out come spring time.
Postby RX-7 Chris » Tue Feb 22, 2011 9:14
Can't wait to see it all together.
Postby coloskydiver » Fri Mar 04, 2011 9:14
I knew it was going to happen but am a little disappointing with some of the bugs I have been having to work out. I JUST WANT TO DRIVE!!!! My clutch keeps going out of adjustment and seems like the master cylinder need braced to prevent flexing. The whole car needed to be raise because the outer CV boot was rubbing on the spring perch and did bottom out on me. I go the car raised and then had the snap ring on the rear spring perch give way and literally drop on axle. So it is currently back at the shop to fix the clutch and re-raise the suspension. I messed with the clutch problem four separate time and each time thought I had it fixed but can only do so much on a garage floor with a Miata 4-pointed. I have been able to get the spoiler installed, suspension aligned, and the stearing wheel straightened out. Hopefully I will get it back soon so I can get the CV boots replaced and be ready for the cruse next week. Wish me luck.
In the meantime, enjoy this video I put together for my dad showcasing my progress. Most of the pics you have already seen but puts them together in chronological order and to music. Enjoy!
[ame="http://www.youtube.com/watch?v=CAmchn24-kQ"]YouTube - V8 Miata Build Progression[/ame]
memphis
Postby memphis » Sat Mar 05, 2011 9:14
Nice video buddy..
Postby coloskydiver » Thu Mar 10, 2011 9:14
The stock 1.6 breaks were defiantly not enough for this car. It would stop but there was a tone of break fade and am under the impression if you can't lock up the breaks, there to small.
I picked up this Wilwood setup for a really good deal which expedited there arrival. They are all installed and just need to bleed them, the clutch is now fixed and CV boots replaced. For now everything is good.
2006 Speed 6- SOLD
2008 Scion Xd- SOLD
Return to “Piston Vehicle”
