ian's all show no go build
Postby chickenwafer » Fri Oct 22, 2010 9:14
LOL you're not going to be able to see out the window soon. I love pedobear tho, I have two on my 8. Still haven't put one on my FD yet tho
Postby iani1.1 » Fri Oct 22, 2010 9:14
haha yea, like mike essa's rx7
Postby RX-7 Chris » Mon Nov 15, 2010 9:14
not sure if this would be any use to you: http://denver.craigslist.org/cto/2060523145.html
Postby iani1.1 » Mon Nov 15, 2010 9:14
i saw that last night. i dont need any interior parts anymore.
i finished both sides of the fender today before it got really cold but it still needs a bit more sanding and bondo but you cant notice the wavyness. ill finish it after the drift event. also installed the coilovers. waiting on the studs, bushings and the dtss eliminators. so itll definitely be kinda completed this week.
You going to try and make it to the meet this week with the car? I'm going to try.
oh definitely. if the parts come in on time.
Postby iani1.1 » Mon Nov 22, 2010 9:14
still having minor problems... but it drives lol
Postby RX-7 Chris » Mon Nov 22, 2010 9:14
Looking Good
Postby speedjunkie » Mon Nov 22, 2010 9:14
That's weird, it didn't seem to drive yesterday LOL.
it drove yesterday. hell, i drove it to andy's house lol. had to stop for a little bit to adjust the camber but only helped a little.
today after messing with it i need a 2mm or 5mm spacer up front to keep it from rubbing on the spring while its at full lock. with a 5mm spacer i think is enough to where itll clear the spring and also i can tuck the front in more and go lower. right now the camber is at +3 which looks a little funky to me.
I don't think you get what I'm saying Ian...obviously it DID NOT drive because you weren't with us. LOL
Postby iani1.1 » Tue Nov 23, 2010 9:14
itll be more driveable when the new engine is in.
Postby iani1.1 » Tue Dec 21, 2010 9:14
went to pull and pay, worked on the car today, still waiting on parts and this is the outcome. i can go lower than this...
Postby erod550 » Tue Dec 21, 2010 9:14
Lower than that? lol the screwdriver could barely roll under your front bumper right now.
it took some thinking just to get it off of the jack stands lol. wood didnt help at all lmao
but this is as low as i can get without having the tire rub on the fender well. i still have about 3/4in between the tire and wheel well.
