My New Toy
I had a coolant hose burst on Wednesday after work. It was the hose that runs below the oil filter. I caught it before the car overheated so the motor is OK. I was able to make a temporary fix to the hose by splicing an elbow. I will replace the hose at some point in the near future.
I made quite a bit of progress this weekend. I flushed the coolant and replaced some of the hoses. I repaired the front bumper. I also repaired the fender as best as I could.
My small oil leak at the oil cooler turned into a waterfall on saturday. I spent a few hours on saturday trying to remove the oil lines from the cooler with no luck. I would on it on sunday and ended up asking Eric for help. We were able to get the lines off. I than walked to the Autozone around the block looking for crush washers. They had an assorted pack but only one. I than walked about a mile to a Checker to get more crush washers and they didn't have any that worked (I did talk to them on the phone). I took this morning off to get the car fixed. I drove all over town looking for crush washers that would work. I ended up going to a different autozone and bought two more assorted packs. It the packs there was one that I needed and a second that was close. I needed two of each. The one that was close, I had to use the dremmel to get it to work. I get all that done and go to put it back into the car only to find out the oil cooler is cracked at the fitting. I than have to take it to a welder to have it repaired. I get the car back together only to find out it is back to leaking. I drive the car to work and it is now leaking quite a bit. THis car is going to be the end of me.
yup it is leaking quite a bit. Also I just had the fuel filter clog and I almost didn't get it into the parking lot at work this morning.
I drove the car to GOTGs on the way home on Friday an took some pics.
As I was leaving GOTGs, I had to stop in a parking lot so I could jack the car up and clean the filter again. I got the car home and pulled the tank. There is still a ton of rust in the tank. I also pulled the oil cooler to see what is leaking. The other bung on the cooler is also cracked and I will need to have that welded as well.
So I'm walking and getting rides untill I can come up with about $150 so I can fix the car. This has to happen on our tightest month ever (no joke).
I guess you posted without seeing my other post, lol.
I can have it dipped and sealed by Manley Radiator in the springs for about $100.
