My New Toy
Postby RX-7 Chris » Fri Oct 29, 2010 9:14
I had a coolant hose burst on Wednesday after work. It was the hose that runs below the oil filter. I caught it before the car overheated so the motor is OK. I was able to make a temporary fix to the hose by splicing an elbow. I will replace the hose at some point in the near future.
Postby iani1.1 » Fri Oct 29, 2010 9:14
One of the heater core hoses? LOL I've had that happen to me.
Postby RX-7 Chris » Mon Nov 01, 2010 9:14
I made quite a bit of progress this weekend. I flushed the coolant and replaced some of the hoses. I repaired the front bumper. I also repaired the fender as best as I could.
My small oil leak at the oil cooler turned into a waterfall on saturday. I spent a few hours on saturday trying to remove the oil lines from the cooler with no luck. I would on it on sunday and ended up asking Eric for help. We were able to get the lines off. I than walked to the Autozone around the block looking for crush washers. They had an assorted pack but only one. I than walked about a mile to a Checker to get more crush washers and they didn't have any that worked (I did talk to them on the phone). I took this morning off to get the car fixed. I drove all over town looking for crush washers that would work. I ended up going to a different autozone and bought two more assorted packs. It the packs there was one that I needed and a second that was close. I needed two of each. The one that was close, I had to use the dremmel to get it to work. I get all that done and go to put it back into the car only to find out the oil cooler is cracked at the fitting. I than have to take it to a welder to have it repaired. I get the car back together only to find out it is back to leaking. I drive the car to work and it is now leaking quite a bit. THis car is going to be the end of me.
Postby speedjunkie » Wed Nov 03, 2010 9:14
So after getting it welded it STILL leaked?! Good grief man haha.
Postby RX-7 Chris » Thu Nov 04, 2010 9:14
yup it is leaking quite a bit. Also I just had the fuel filter clog and I almost didn't get it into the parking lot at work this morning.
Postby tsx_guy » Thu Nov 04, 2010 9:14
RX-7 Chris wrote:yup it is leaking quite a bit. Also I just had the fuel filter clog and I almost didn't get it into the parking lot at work this morning.
crap dude...that's bad.
barely making it to work probably means you won't be delivering tut's couch tonight?
Postby speedjunkie » Thu Nov 04, 2010 9:14
Damn Chris. This car WILL be the death of you haha.
Postby RX-7 Chris » Mon Nov 08, 2010 9:14
I drove the car to GOTGs on the way home on Friday an took some pics.
As I was leaving GOTGs, I had to stop in a parking lot so I could jack the car up and clean the filter again. I got the car home and pulled the tank. There is still a ton of rust in the tank. I also pulled the oil cooler to see what is leaking. The other bung on the cooler is also cracked and I will need to have that welded as well.
So I'm walking and getting rides untill I can come up with about $150 so I can fix the car. This has to happen on our tightest month ever (no joke).
Postby tsx_guy » Mon Nov 08, 2010 9:14
nice! I didn't see any sign of an oil trail either.
I guess you posted without seeing my other post, lol.
RX-7 Chris wrote:I guess you posted without seeing my other post, lol.
yup...i missed your follow up post. dude i am sorry...
Postby iani1.1 » Mon Nov 08, 2010 9:14
im starting to think that tank isnt worth it anymore. you probably have more luck getting a new/used one lol
I can have it dipped and sealed by Manley Radiator in the springs for about $100.
RX-7 Chris wrote:I can have it dipped and sealed by Manley Radiator in the springs for about $100.
will this address/resolve the rust issues?
Users browsing this forum: Google [Bot] and 60 guests
