Hey guys I have read some of the info on rear engine mounts ,hear and on the interwebs . Too many choices AAAHHH help ! Which brand is the best and Do I really need the side engine mounts ? I trust you guys. You have so much more expierence than I do . Thanks again Patrick
anybody use Suremotorsports?
rear and side engine mounts Help !
- KILLER_VIZ
I had all 3 Street Unit mounts and they worked great. I had zero wheel hop. But just be prepared once you put the side mounts on you will hear every little noise and rattle and grind and whine your transmission makes. You get used to it after a while but it's pretty annoying at first.
I'd try just the rear mount first and see how much wheel hop you have still. If it's minimal and you're only planning on doing a few bolt-ons, you might be able to get away with just the rear.
Users browsing this forum: Baidu [Spider] and 80 guests
