rear and side engine mounts Help !
pyrrhus17
Postby pyrrhus17 » Sun Mar 04, 2012 9:14
Hey guys I have read some of the info on rear engine mounts ,hear and on the interwebs . Too many choices AAAHHH help ! Which brand is the best and Do I really need the side engine mounts ? I trust you guys. You have so much more expierence than I do . Thanks again Patrick
anybody use Suremotorsports?
42boxer
Postby 42boxer » Sun Mar 04, 2012 9:14
pyrrhus17
Wow missed that one thanks !
Mortose
Postby Mortose » Sun Mar 04, 2012 9:14
my opinion, but i'm going to be going with the JBR RMM. and eventually all the way around with JBR. lol
KILLER_VIZ
Postby KILLER_VIZ » Sun Mar 04, 2012 9:14
Go with the JBR trilogy mount set. If your planning to go BT go ahead and get the 88 so you dont have to buy new ones later on.
42boxer
Ive heard really good of the street unit 3 set. Id like to get some but there lower down on my list
Postby erod550 » Mon Mar 05, 2012 9:14
I had all 3 Street Unit mounts and they worked great. I had zero wheel hop. But just be prepared once you put the side mounts on you will hear every little noise and rattle and grind and whine your transmission makes. You get used to it after a while but it's pretty annoying at first.
I'd try just the rear mount first and see how much wheel hop you have still. If it's minimal and you're only planning on doing a few bolt-ons, you might be able to get away with just the rear.
