Cobb Dyno
PeZ3o3
Cobb Dyno
Postby PeZ3o3 » Mon Nov 21, 2011 9:14
Does anyone kno how accurate the cobb dyno is? I did a run getting onto the freeway a while ago and finally checked the numbers. 360hp 413tq. At best I would think thats at the crank. Idk if the numbers need to be modified or something. If that is right then im pretty f'in proud.... zoom zoom bitches
Think I drive fast? You should see me ski.
Postby erod550 » Mon Nov 21, 2011 9:14
Not accurate at all. They tend to vary each time you test it. I wouldn't take any hp numbers seriously from any electronic device that isn't a real dyno.
PeZ3o3
thats what i figured. thanks man. stupid ap got me all excited
Postby ~Barn~ » Mon Nov 21, 2011 9:14
Just poll it like 10 times, throw out both the highest and lowest values, and then average the remaining 8.
That's Olympic-level accuracy, right there!
Image 720.935.6438
Shooter McGavin
Postby Shooter McGavin » Mon Nov 21, 2011 9:14
Check out the Virtual Dyno Program, guys over on MSF.org have been saying its actually fairly accurate.
http://www.mazdaspeedforums.org/forum/f505/virtual-dyno-85289/
No regrets, that's my motto.....That and everybody Wang Chung tonight.
RichB
Postby RichB » Mon Nov 21, 2011 9:14
Shooter McGavin wrote:Check out the Virtual Dyno Program, guys over on MSF.org have been saying its actually fairly accurate.
I also use Virtual Dyno and I haven't verified my numbers but it is pretty consistent with each run. I never even tried the Cobb dyno.
With VD, you can definitely use it to see what gains you get from any mods.
Postby chickenwafer » Mon Nov 21, 2011 9:14
When I used the AP dyno on my old turbo RX-8 I got anything from a best of 440rwhp to a low of 220ish rwhp. It's a joke.
The only performance measuring in the AP I found useful was the 1/4 mile and 0-60 timer. Since these use the factory speedo and odometer to compute these, they are pretty accurate. I would use the 0-60mph timer to gauge mods before and after, and it was actually pretty useful.
PeZ3o3
Postby PeZ3o3 » Wed Nov 23, 2011 9:14
right on thanks for the info everybody! im gonna check that program out, seems pretty cool
Users browsing this forum: No registered users and 93 guests
