Looking for someone that does plating in C Springs
Postby speedjunkie » Tue Feb 22, 2011 9:14
I looked it up on Yahoo local but it only shows one powdercoating place, Platinum Powder Coating.
I thought I could anodize the pieces until I was told you can only anodize aluminum, I didn't know that. I'd think about just getting them powder coated but one of them is the trigger wheel for the ignition system and I don't want to cover up the tabs that the crank angle sensors read from because it's magnetic and I don't want to take any chances messing it up. I have a few pieces I'd like to get done and I have some other pieces I'd be happy powder coating.
I already have all my intake piping, manifolds etc up at Premier Coatings and he should be done with them soon, but I don't feel like dropping off another batch of things I would need to drive all the way up there to pick up again.
I thought about painting these pieces but paint doesn't seem to last very long without flaking off or scratching so I want something more durable and resistant to knicks from a stray screwdriver or wrench. Someone had mentioned black cadmium plating so I'd like to look into that.
I've even thought about taking my aftermarket pulleys to get anodized in black. Easier to keep clean (or harder to notice when it's dirty lol) and I'm going all black with everything else anyway.
Postby iani1.1 » Tue Feb 22, 2011 9:14
Postby speedjunkie » Wed Feb 23, 2011 9:14
Isn't that just paint? That's not what I'm looking for, but thanks for playing LOL.
Postby iani1.1 » Wed Feb 23, 2011 9:14
lol sorry im just being an ***. but yea i have no idea to get anything done in the springs area.
Postby RX-7 Chris » Wed Feb 23, 2011 9:14
I bet someone on HPJunkies knows a good plating place.
Postby speedjunkie » Thu Feb 24, 2011 9:14
iani1.1 wrote:lol sorry im just being an ***. but yea i have no idea to get anything done in the springs area.
How is that different from usual? LOL j/k
RX-7 Chris wrote:I bet someone on HPJunkies knows a good plating place.
True, I hadn't thought of that. Thanks!
Postby iani1.1 » Thu Feb 24, 2011 9:14
what can i say im a fc owner. LOL.
Postby RX-7 Chris » Fri Feb 25, 2011 9:14
Any update on a plating place. I have a bunch of parts I need to have plated gold zinc.
Postby speedjunkie » Sat Feb 26, 2011 9:14
One of the guys on CHPJ told me about Ximpak, it's out off Garden of the Gods road. I called them today (well, Friday afternoon) but they close at noon on Fridays. I left a message, hopefully they'll call me back on Monday.
On a side note, I got my stuff back from Premier Coatings today, and it all looks GREAT!
Postby chickenwafer » Sat Feb 26, 2011 9:14
What did you get powdercoated man?
Post up pics! I am debating polishing or powdercoating my UIM and LIM
Postby iani1.1 » Sat Feb 26, 2011 9:14
oh man those finished pieces look real nice.
I'll post up pics when I get a chance, but here is what I got done:
Powder coated-
all IC piping
IC except for fins
UIM
GReddy elbow
compressor housing
ceramic coated-
downpipe
manifold
turbine housing
LIM
What color did you get? Do they have any shiny colors like a polished or chrome look (without actually being chrome, this isn't a Harley)
Postby speedjunkie » Sun Feb 27, 2011 9:14
I got it all black. They have ceramic in a polished look but I'm not sure about powder coat. You could always get it everything ceramic coated but it would be more expensive. It does form a heat barrier though, which is why I had the LIM done in ceramic.
Postby speedjunkie » Thu Mar 10, 2011 9:14
I don't remember where I posted pics of the powder coated and ceramic coated stuff but here it is again.
And here are the brackets and things that I had done in black oxide.
And here is the cruise control module, I had the bracket done in black oxide.
I'm going to get some other stuff anodized and some other things powder coated. So almost everything will be black. I'm still trying to figure out how to do the throttle body without removing everything.
I've also been working on a couple other little projects. One is finally mounting the relay box. I got some riv-nuts and installed them into the front cross member. I don't know why I never thought of doing it this way before. I wanted to make it at least somewhat accessible just in case a relay goes bad. This way I can still open the top without removing anything. The only problem is I'll have to lay down in front of the car and access it through the IC/radiator opening in the bumper.
I'm also modifying my DIN gauge cluster to hold my boost controller and connectors for tuning. I had already cut the boost controller portion open a few weeks ago. I'm just now getting around to trying to finish it up.
Test fitting with the boost controller...
Ready to mold the pieces together, just not sure how to do it the cleanest way lol. I'm thinking of just doing JB weld on the back and then fill the small cracks on the front with resin, sanding it down and painting it. I still have to cut one more hole under the other connector ports, but I'm trying to decide if I want it to be for the water injection USB cable or the switch to turn on the wideband.
I have several other projects too, but I haven't gotten to some of them yet. My engine should be back in a week or so I'm hoping. We'll see though.
