I looked it up on Yahoo local but it only shows one powdercoating place, Platinum Powder Coating.
I thought I could anodize the pieces until I was told you can only anodize aluminum, I didn't know that. I'd think about just getting them powder coated but one of them is the trigger wheel for the ignition system and I don't want to cover up the tabs that the crank angle sensors read from because it's magnetic and I don't want to take any chances messing it up. I have a few pieces I'd like to get done and I have some other pieces I'd be happy powder coating.
I already have all my intake piping, manifolds etc up at Premier Coatings and he should be done with them soon, but I don't feel like dropping off another batch of things I would need to drive all the way up there to pick up again.
I thought about painting these pieces but paint doesn't seem to last very long without flaking off or scratching so I want something more durable and resistant to knicks from a stray screwdriver or wrench. Someone had mentioned black cadmium plating so I'd like to look into that.
I've even thought about taking my aftermarket pulleys to get anodized in black. Easier to keep clean (or harder to notice when it's dirty lol) and I'm going all black with everything else anyway.
Looking for someone that does plating in C Springs
I bet someone on HPJunkies knows a good plating place.
Any update on a plating place. I have a bunch of parts I need to have plated gold zinc.
One of the guys on CHPJ told me about Ximpak, it's out off Garden of the Gods road. I called them today (well, Friday afternoon) but they close at noon on Fridays. I left a message, hopefully they'll call me back on Monday.
On a side note, I got my stuff back from Premier Coatings today, and it all looks GREAT!
I don't remember where I posted pics of the powder coated and ceramic coated stuff but here it is again.
And here are the brackets and things that I had done in black oxide.
And here is the cruise control module, I had the bracket done in black oxide.
I'm going to get some other stuff anodized and some other things powder coated. So almost everything will be black. I'm still trying to figure out how to do the throttle body without removing everything.
I've also been working on a couple other little projects. One is finally mounting the relay box. I got some riv-nuts and installed them into the front cross member. I don't know why I never thought of doing it this way before. I wanted to make it at least somewhat accessible just in case a relay goes bad. This way I can still open the top without removing anything. The only problem is I'll have to lay down in front of the car and access it through the IC/radiator opening in the bumper.
I'm also modifying my DIN gauge cluster to hold my boost controller and connectors for tuning. I had already cut the boost controller portion open a few weeks ago. I'm just now getting around to trying to finish it up.
Test fitting with the boost controller...
Ready to mold the pieces together, just not sure how to do it the cleanest way lol. I'm thinking of just doing JB weld on the back and then fill the small cracks on the front with resin, sanding it down and painting it. I still have to cut one more hole under the other connector ports, but I'm trying to decide if I want it to be for the water injection USB cable or the switch to turn on the wideband.
I have several other projects too, but I haven't gotten to some of them yet. My engine should be back in a week or so I'm hoping. We'll see though.
