Moisture in headlight
Postby TheNewBlack » Mon Oct 18, 2010 9:14
So, for the past couple weeks I've noticed moisture in my housing after I wash the car, or even after a little rain. I have HID's on the car but dont think this is the cause. The seals behind all the bulbs look perfect. Im pretty stumped, and know the dealership will give me some BS about the HID's....any ideas out there?
reconbygod12
Postby reconbygod12 » Mon Oct 18, 2010 9:14
your hids might of came lose from just normal wear and tear of driving causing water to flter into the housing and jus ta little water can cause it all to moisture up
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
What do you mean by loose?, the seals are tight and dont move at all.
Operator
Postby Operator » Mon Oct 18, 2010 9:14
Have you ever opened up your housing? If not, I'd re-seat ALL the bulbs just in case. And depending on the kit, it is possible the HID bulbs don't fit as snug as OEM.
JL 1000/1 - JL 450/4
[/font]
Current:
Postby GR-8 » Mon Oct 18, 2010 9:14
I had moisture in the rear tail light of my 8. I just dumped all the water out that was in there and reattached it. I also had to super glue a stud that broke off of it from when it was hit. So that might have helped it seal up. Maybe it's just loose and the seals appear to be tight?
I've also heard that drilling a small hole at the bottom and/or top will let moisture escape and it shouldn't fog up.
jankyboy
Postby jankyboy » Tue Oct 19, 2010 9:14
Can you remove the HIDs and get it back to looking stock for a trip to the dealer?
I had my passenger headlight assembly replaced under warranty last month because of moisture. I have the stock HIDs, though. When I brought it in, they ran the hose over the assembly until they noticed the moisture inside. I'd imagine if you roll in with water already in there, you could argue for a warranty replacement.
2010 Mazda 3s GT
Mods: Enkei PF01 18x7.5 +38 wheels wrapped in 225/40-ZR18 Michelin Pilot Sport A/S Plus // Simota SRI // Koni FSD struts and shocks // Road Magnet 1.25" springs // Racing Beat exhaust // Racing Beat rear sway bar // Painted calipers // Philips Ultinon 6000K HID bulbs // Höen xenonmatch fog bulbs
Postby geo2maz » Tue Oct 19, 2010 9:14
I think at some point I asked this question somewhere over a year ago when I was car shopping and kept seeing moisture in the headlights on pictures of cars that were for sale... People generally thought it was condensation and that if the moisture is only there for an hour or so after the car has been washed, then it's nothing to worry about...
(I kept seeing it in pictures bc dealerships and people usually wash the car right before their photo-shoot)
Postby TheNewBlack » Tue Oct 19, 2010 9:14
jankyboy wrote:Can you remove the HIDs and get it back to looking stock for a trip to the dealer?
I could take them out, it would be obvious i messed with the wiring though. I might just bring it in anyway and see what happens...
geo2maz wrote:I think at some point I asked this question somewhere over a year ago when I was car shopping and kept seeing moisture in the headlights on pictures of cars that were for sale... People generally thought it was condensation and that if the moisture is only there for an hour or so after the car has been washed, then it's nothing to worry about...
It stays in there for about 2 days after I wash the car....so it bothers me, if it were minor, I wouldnt be too worried about it.
Operator
Postby Operator » Tue Oct 19, 2010 9:14
TheNewBlack wrote:I could take them out, it would be obvious i messed with the wiring though. I might just bring it in anyway and see what happens...
Why? When I did my HID swap all OEM wires were left intact and in their original bundles.
[/font]
Current:
Well I washed it today after reseating all the bulbs on that housing and no moisture. Something must have just come loose. We'll see if it happens again. Thanks for all your input.
