New 2871 setup
rmeeker13
New 2871 setup
Postby rmeeker13 » Mon Oct 11, 2010 9:14
Well I finally got er running, got the fmic and intake done. Relocated the maf to right in front of the throttle body so I can run vta. Still need to work out some kinks regaurding the boost controller and tuning the maf. Alsio having some vacum issues...when I installed my synapse bov and the car was idling the valve was stuck open and causing it to run lean. Anyone have any thoughts regaurding the vac issue? When I took the car for a spin I got into boost a little bit and the silicone coupler connected to the turbo blew off(didn't have the clamp tight enough!) so that was exciting! haha
Anyway's heres a few pics of the final install!
[ATTACH]1529[/ATTACH][ATTACH]1530[/ATTACH]
[ATTACH]1531[/ATTACH][ATTACH]1532[/ATTACH]
Postby tbot » Mon Oct 11, 2010 9:14
Very nice!!! Lets get that beast tuned and running strong!!!
rush24
Postby rush24 » Mon Oct 11, 2010 9:14
Nice.....let me know how that fmic works out...had the same thing happen to me with the turbo hose...
Isn't there an adapter for the Synapse for VTA so that doesn't happen??
http://synapseengineering.com/smf/index.php?topic=353.0
2007 Black CX7
Apexcone Raptor 6000k HID...
3" DP back Exhaust System
SURE Motor Mount...
[/color]
speedlovin
Postby speedlovin » Mon Oct 11, 2010 9:14
I would contact Revolutions Performance and ask them for some suggestions and such. They are pretty good in assisting people and offer suggestions.
LET THE BEST THING ABOUT YOUR JOB BE THE DRIVE THERE AND BACK
rmeeker13
rush24 wrote:Nice.....let me know how that fmic works out...had the same thing happen to me with the turbo hose...
Thats exactly what I need! Thanks buddy
Postby Stealth01 » Mon Oct 11, 2010 9:14
That's the BT I want in about 2.5 years, when this POS is paid off. Seems like the best DD BT out there, and should give me exactly what I want in the vehicle at that point. I don't want a dyno-queen or a drag strip rocket. Just something that does 0-60 under five seconds and has enough top-end power to be fun. If I track it, it'll be road courses.
rush24
rmeeker13 wrote:Thats exactly what I need! Thanks buddy
No problem...I was thinking about running VTA when I had my synapse...but not any more...
Let me know if that fmic doesn't work...we can swap fmic's... Mine is bigger:D
2007 Black CX7
SURE Motor Mount...
[/color]
Regulator
Postby Regulator » Tue Oct 12, 2010 9:14
Thats my cars dream turbo right there!
Postby erod550 » Tue Oct 12, 2010 9:14
Nothing holding down your battery?
rmeeker13
Postby rmeeker13 » Tue Oct 12, 2010 9:14
speedlovin wrote:I would contact Revolutions Performance and ask them for some suggestions and such. They are pretty good in assisting people and offer suggestions.
I got er figured out...but thanks.
Stealth01 wrote:That's the BT I want in about 2.5 years, when this POS is paid off. Seems like the best DD BT out there, and should give me exactly what I want in the vehicle at that point. I don't want a dyno-queen or a drag strip rocket. Just something that does 0-60 under five seconds and has enough top-end power to be fun. If I track it, it'll be road courses.
Well once I get er all tuned up well have to meet and I'll let ya see what you think!
rush24 wrote:No problem...I was thinking about running VTA when I had my synapse...but not any more...
I'll let you know...I'm not sure I could go bigger without cutting the crashbar?
Regulator wrote:Thats my cars dream turbo right there!
Oh come on now...there's waaayyyy better setups out there now! I'd actually go a bit bigger but I have no plans on building the motor unless I grenade it! So it is perfect for a DD.
erod550 wrote:Nothing holding down your battery?
Ya noticed did ya! Well I'm actually going to put the batt in the trunk to get rid of the clutter. Plus my intake is 3.5'' so it don't fit like the cp-e inlet/intake did! Just not enough damn room! Actually I could make a bracket to replace the tray and make it work but I like the batt in the back.
They won't let you run at the track without a hold-down, if you were planning on running at the track. That won't matter if you move it to the trunk of course.
rmeeker13
erod550 wrote:They won't let you run at the track without a hold-down, if you were planning on running at the track. That won't matter if you move it to the trunk of course.
Yeah but also if I put it in the trunk I will have to run an external on/off switch for the track. Well see what happens, if I go up to bandimere next year I'll have it all worked out. My brother used to run a 10sec 73 camaro in King Street for years so I grew up at the track...still remember most of the saftey shit!
rush24
Postby rush24 » Tue Oct 12, 2010 9:14
Did you order that Synapse kit yet? Check eBay if you haven't...it may be cheaper...
2007 Black CX7
SURE Motor Mount...
[/color]
rmeeker13 wrote:Yeah but also if I put it in the trunk I will have to run an external on/off switch for the track. Well see what happens, if I go up to bandimere next year I'll have it all worked out. My brother used to run a 10sec 73 camaro in King Street for years so I grew up at the track...still remember most of the saftey shit!
Nice! Never mind then. It was just something that stuck in my mind from looking at the list of safety stuff when I went last week.
Postby ~Barn~ » Tue Oct 12, 2010 9:14
Damn Meeker... You are all kinds of Jekyll and Hyde with that car! I love it.
I just want you to get vanity plates: MONSTER
Image 720.935.6438
Users browsing this forum: No registered users and 113 guests
