Cel
- MN Speedster
- Junior Member
Cel
Car threw a CEL last night, got it scanned at autozone and it was P0406 and P0407. Any ideas what could be causing it?
[font="Century Gothic"]2008 CWP Speed3[/font]
COBB short ram intake, SU Motor Mounts, Prosport Boost gauge,Yellow Fog Light Overlays
[color="Blue"]Flick[color="Magenta"]r[/color][/color]
- MN Speedster
- Junior Member
I've researched the codes and they relate to the EGR valve. Would it be best to take it to a dealer? Its still under warranty. Any mod friendly dealers in the area?
I have an OBD II scanner. If you want to come by, you're welcome to use it to get some more details about the codes, and of course reset them.
[EDIT:] From what I found on the net with a quick search, these two code have to do with "High Circuit" reading on both your sensor A and sensor B, on your EGR valve.
- MN Speedster
- Junior Member
Cars been running fine, disconnected the battery to reset the code and so far the light has stayed off, if it pops up again its off to the dealer. Thanks guys
- MN Speedster
- Junior Member
Well popped back on today, any suggestions for which dealer to take it to?
