Cel
MN Speedster
Junior Member
Cel
Postby MN Speedster » Sat Jun 19, 2010 9:14
Car threw a CEL last night, got it scanned at autozone and it was P0406 and P0407. Any ideas what could be causing it?
[font="Century Gothic"]2008 CWP Speed3[/font]
COBB short ram intake, SU Motor Mounts, Prosport Boost gauge,Yellow Fog Light Overlays
[color="Blue"]Flick[color="Magenta"]r[/color][/color]
Postby AIM WO4 » Sat Jun 19, 2010 9:14
Did you fill up? Maybe the gas cap? Looks like an emissions code.
Postby TheNewBlack » Sat Jun 19, 2010 9:14
Yeah it's an exhaust code.
MN Speedster
Junior Member
I've researched the codes and they relate to the EGR valve. Would it be best to take it to a dealer? Its still under warranty. Any mod friendly dealers in the area?
Dealerships won't care about just an SRI and mounts. Is the car running okay? If it were me I'd just disconnect the battery for a couple minutes, that will should clear the CEL. Then see if you get that code again, if so I'd go to the dealership if you're under warranty.
Postby ~Barn~ » Sat Jun 19, 2010 9:14
I have an OBD II scanner. If you want to come by, you're welcome to use it to get some more details about the codes, and of course reset them.
[EDIT:] From what I found on the net with a quick search, these two code have to do with "High Circuit" reading on both your sensor A and sensor B, on your EGR valve.
MN Speedster
Junior Member
Postby MN Speedster » Sun Jun 20, 2010 9:14
Cars been running fine, disconnected the battery to reset the code and so far the light has stayed off, if it pops up again its off to the dealer. Thanks guys
MN Speedster
Junior Member
Postby MN Speedster » Mon Jun 28, 2010 9:14
Well popped back on today, any suggestions for which dealer to take it to?
mOOsE
Postby mOOsE » Wed Jun 30, 2010 9:14
MN Speedster wrote:Well popped back on today, any suggestions for which dealer to take it to?
Heard Burt is good, and so is Sil-Terhar.
Users browsing this forum: No registered users and 175 guests
