Road Trip!!
Road Trip!!
Postby Stealth01 » Fri Jun 11, 2010 9:14
OK, so Thursday morning, my son and I take off in the MS6 for a visit to University of Utah in Salt Lake City. I'm teaching him to drive a stick so he can share some driving fun, but I have to admit -- I'm a little nervous about the car. It's apparently long trips at highway speeds that kill the DISI 2.3L and contribute to Zoom-Zoom-Boom, so I'm REALLY hoping we make it without incident. Not sure of our route yet...but I suspect it'll be I-70 through the mountains...WEEE!!!!
WIsh us luck, and keep your fingers crossed!
Postby iani1.1 » Fri Jun 11, 2010 9:14
just make sure he doesnt hit any curbs and blows a tire lol
good luck with the trip, i-70 is extremely fun this time of year. i went to grand junction to pick up a hood not too long ago, just the drive alone was worth it.
LOL, yeah he won't be driving through the mountains. That'll be me.
Postby kingtut » Fri Jun 11, 2010 9:14
Yup, I make that trip maybe once every year or two. I took the WY route once, only due to my 2WD 4 banger. Otherwise, its been I-70
So the I-70 route is quicker?
Stealth01 wrote:So the I-70 route is quicker?
I'm pretty sure it is.
Wyoming is a totally boring drive though- well, might be better for learning though:huh:
I've checked Google Earth/Maps, Mapquest, and the GPS function on my droid. All of them said to go I25 to I80. Maybe we'll take that way out there, and do I70 on the way back....
Interesting. I just Mapquested it. MQ says that I-80 is the shortest time and I-70 is the shortest distance.
It also had this note about I-70:
Note to I-70 Travelers in Colorado: I-70 is restricted to one lane in each direction between approximately Dotsero and Glenwood Springs due to ongoing repairs after a rock slide in Glenwood Canyon. Speed limits through this area are reduced to 40mph and vehicles over 14 feet wide are required to detour. These restricted conditions are expected to be in place for several weeks. You can drag your route to find alternative routes around this area. In addition, we suggest you go to the Colorado DOT site for updates on this road project. For your safety, always obey local construction and detour signs.
Maybe that's why they're routing me through the armpit of the west...to get around the construction.
Yup, most likely. I guess we know which way you'll be taking:lol:
kingtut wrote:Yup, most likely. I guess we know which way you'll be taking:lol:
I'll probably still come back I-70, so I can have some rally fun in the mountains. :)
Dange
Postby Dange » Fri Jun 11, 2010 9:14
i heard about the whole freeway zomzoomboom issue. iirc i *heard* apparently its from sitting in vacuum for so long that it sucks up oil from the crankcase and to prevent it is to get into a bit of boost every 20minutes or so and clear it out. i guess its speculation but my buddy errs on the side of caution and follows it religiously
04MSMGT
Dange wrote:i heard about the whole freeway zomzoomboom issue. iirc i *heard* apparently its from sitting in vacuum for so long that it sucks up oil from the crankcase and to prevent it is to get into a bit of boost every 20minutes or so and clear it out. i guess its speculation but my buddy errs on the side of caution and follows it religiously
That makes sense...I'll have to go into boost a lot. LOL
Postby tbot » Sat Jun 12, 2010 9:14
^^thats basically the case. The oil vapors aren't removed correctly with the shitty pcv system on our cars so the oil vapors condense in the intake manifold. After the long haul and then exiting you'll most likely get into boost which sucks the oil build up from the intake manifold into the center cylinders (mainly cylinder number 3 iirc) and hydrolocks that cylinder pushing a rod thru the block.
so yes, basically the best way to prevent the large amount of oil build up is to get into boost frequently (who WOULDN'T want to do that) to basically suck smaller amounts of oil thru the motor.
FYI, sounds like your next "mod" needs to be an oil catch can lol.
GL with the trip, and remember to stay "spirited" with your driving ;);)
Postby Stealth01 » Sat Jun 12, 2010 9:14
That's going to KILL our gas mileage, but if it staves off the BOOM, we'll do it. Lex seems to think we'll be all right, so I'm not too worried.
Users browsing this forum: No registered users and 159 guests
