Wondering what this could be
my protege has been kinda messing up when i accelerate the needle on my boost gauge shakes up and my vacuum pressure is at 22 so im curious what it could be if anyone could help me out that would be greatly appreciated. my friend says he thinks its my valve springs i just want to get other opinions
LaginWagon
LaginWagon
- 7th Heaven
- Member
The problem could be weak valve springs. Youll have normal vacuum and the needle will fluctuate excessibly at higher speeds. This can also be a Fuel injector problem which will make the needle slowly drift back and fourth. Also you have that cheap ass boost controller which could be adjusted to a setting your Stock PCM isnt familiar with and that could be giving your car whack readings. A bad sensor could be at play. Your Map sensor is very important and could be bad. There can be a hundred of things that could be goin on though.
Users browsing this forum: Google [Bot] and 121 guests
