Wondering what this could be
Chrisba
Postby Chrisba » Tue Nov 24, 2009 9:14
my protege has been kinda messing up when i accelerate the needle on my boost gauge shakes up and my vacuum pressure is at 22 so im curious what it could be if anyone could help me out that would be greatly appreciated. my friend says he thinks its my valve springs i just want to get other opinions
LaginWagon
Postby LaginWagon » Tue Nov 24, 2009 9:14
Need more info than this. What is "shakes up"? Does the car react as expected, or is it (mimicking) different as the boost gauge is? Mech' or elec' gauge?
You can't just jump to "it's your valve springs". You're buddy might as well say "it's youir Flux Capicitor." It's not that either, trust me.
Postby tbot » Tue Nov 24, 2009 9:14
punctuation would be good too! But agreed, more info is needed than given.
Postby chickenwafer » Tue Nov 24, 2009 9:14
LOL at "vacuum pressure". That's an oxymoron. But anyways, if you are pulling 22 inches of mercury in vacuum then your motor is in A++ shape.
Chrisba
Postby Chrisba » Wed Nov 25, 2009 9:14
ok well the check engine light came on and i checked it out and it says lean air to fuel ratio. and the needle when you step on the gas instead of going up smoothly it goes up and down really fast.
LaginWagon
Postby LaginWagon » Wed Nov 25, 2009 9:14
Possibly a MAP and/or MAF sensor. Could also be 100 other things.
Postby chickenwafer » Thu Nov 26, 2009 9:14
Boost leak, or you're over-boosting and the PCM is going into limp mode (very, extremely common in MSP's), faulty sensor but you would probably get a CEL for that as well...
7th Heaven
Postby 7th Heaven » Sun Jan 24, 2010 9:14
The problem could be weak valve springs. Youll have normal vacuum and the needle will fluctuate excessibly at higher speeds. This can also be a Fuel injector problem which will make the needle slowly drift back and fourth. Also you have that cheap ass boost controller which could be adjusted to a setting your Stock PCM isnt familiar with and that could be giving your car whack readings. A bad sensor could be at play. Your Map sensor is very important and could be bad. There can be a hundred of things that could be goin on though.
Users browsing this forum: Baidu [Spider] and 75 guests
