VG shark fin
VG shark fin
Postby kingtut » Fri Oct 17, 2008 9:14
The stock antenna doesn't really bother me much. However, once the bad weather hits, I'm covering the MS3. I bought a cover and from glancing at the directions, it looks like I need to cut a hole in the cover to allow for the antenna to go through. Sounds pretty stupid to me- So I figured why not just go to the shark fin so I don't have to put a hole in a perfectly good cover.
I've seen that some of the antennas don't work with the VG shark fin. I've got a 2008.5 without satellite (sport model). Has anyone else put one of these fins on thier comparable MS3? ...and if so, does it negatively effect radio reception?
Postby tsx_guy » Fri Oct 17, 2008 9:14
Can't you just take the antenna off? i think it just unscrews?
I have the sharkfin on my car, not a ms3, but it seems to do okay.
functions about the same as inglass antennas do.
6i_guy wrote:Can't you just take the antenna off? i think it just unscrews?
Take it off ya say? Hmmm...never thought about that (big surprise there). I'll have a look when I get home. If I can unscrew it, then problem solved :)
firestoned
Postby firestoned » Fri Oct 17, 2008 9:14
yes, it unscrews
Thanks to Guido and Eric, it does indeed unscrew.
