alternator removal instructions
firestoned
Postby firestoned » Mon Oct 13, 2008 9:14
Does anybody have instructions on how to remove the alternator off the speed 6? I've done some searching, but no luck so far..
bobopud
Postby bobopud » Mon Oct 13, 2008 9:14
Good luck, the alternator is in one of the worst spots possible. It looks like you almost need to lift the engine to get it out, but I haven't seen any kind of instructions for it. Good luck.
Postby MazdaTom » Mon Oct 13, 2008 9:14
Is it bad or are you just wondering?
It's not an easy job on the Protege either. It's either remove the intake manifold or remove the driveshaft.
firestoned
The oil line going to the turbo is leaking on the block side, which sits right behind the alternator.. I can get to the three bolts holding the alternator on, but getting that damn belt off is whats holding me back now...
You took the tension off the belt, right?
firestoned
the tensioner wont move, dont understand...I pryed the belt off the tensioner, its off now, I will have to definitely figure out how to get rid of the tension to reinstall
firestoned
allz good, found the leak, tightened er up, and Im keeping oil in now...
Users browsing this forum: Bing [Bot] and 133 guests
