Something Intresting For Mt 8 Owners.
Postby GR-8 » Thu Oct 18, 2007 9:14
I just remembered this. I've known about it for like forever and thought I'd share. I remembered about it when I was heading down to home depot. You can shift without using the clutch.
Warning this only works after first gear. so from 2-3, 3-4, 4-5, 5-6. Try at own risk.
I'm sure this works with other MT as well. Saves from pressing in the clutch all the time. Especially when just cruising.
This also works to down shift but you have to rev up to the right rpm before it you can put it into gear.
OpacRX
Postby OpacRX » Thu Oct 18, 2007 9:14
<div class='quotetop'>QUOTE (Greek8 @ Oct 18 2007, 05:13 PM) [url=index.php?act=findpost&pid=6474]<{POST_SNAPBACK}>[/url]</div>
This also works to down shift but you have to rev up to the right rpm before it you can put it into gear.[/b]
Yeah i think i will just push the clutch in every time it don't take to much to do [img]http://coloradomazdaclub.com/forums/style_emoticons/<#EMO_DIR#>/79731810.gif[/img]
Postby Huzer21 » Fri Oct 19, 2007 9:14
I'm clutchless when I ride any bikes, but not for my car.
