I just remembered this. I've known about it for like forever and thought I'd share. I remembered about it when I was heading down to home depot. You can shift without using the clutch.
Warning this only works after first gear. so from 2-3, 3-4, 4-5, 5-6. Try at own risk.
I'm sure this works with other MT as well. Saves from pressing in the clutch all the time. Especially when just cruising.
This also works to down shift but you have to rev up to the right rpm before it you can put it into gear.
Something Intresting For Mt 8 Owners.
OpacRX
<div class='quotetop'>QUOTE (Greek8 @ Oct 18 2007, 05:13 PM) [url=index.php?act=findpost&pid=6474]<{POST_SNAPBACK}>[/url]</div>
Yeah i think i will just push the clutch in every time it don't take to much to do [img]http://coloradomazdaclub.com/forums/style_emoticons/<#EMO_DIR#>/79731810.gif[/img]
This also works to down shift but you have to rev up to the right rpm before it you can put it into gear.[/b]
