Daylight Savings?
Postby tbot » Sun Mar 09, 2008 9:14
So i was just curious if anyone was going to change the time on the site now that daylight savings kicked in...
Postby Huzer21 » Sun Mar 09, 2008 9:14
Maybe you'll have to change the settings for your profile. The times I see on the site are correct. Just verify you're using the correct time zone in your profile.
You can check this by going to "My Control Panel", Down on the left, under options , there's "board settings". At the top, it lists the time zone, and there's a checkbox to automatically adjust to DST.
weird...i had all the settings correct...but for like 30 minutes it didn't update...now everything is fine...
Postby GR-8 » Sun Mar 09, 2008 9:14
Quick fix for this is to log out and log back in if all your settings are correct and time is still wrong.
Postby GR-8 » Tue Mar 11, 2008 9:14
<div class='quotetop'>QUOTE (Greek8 @ Mar 9 2008, 05:09 PM) [url=index.php?act=findpost&pid=31048]<{POST_SNAPBACK}>[/url]</div>
Quick fix for this is to log out and log back in if all your settings are correct and time is still wrong.[/b]
I have an Update on my quick fix. As I just found out it is a temporary fix. If most of you are like me and have CMZC set as a home page the real fix should be to make sure your settings are correct as Huzer (Tim) pointed out in the second post. When that is done log out and log back in. Your time will be correct. Now the next step to permanantly fix this is to reset the Club page as your home page. This will reset the refreshed settings.
Postby MazdaTom » Wed Mar 12, 2008 9:14
My settings flip-flop back and forth. Right now it says it's 6:47 am, but it's actually 7:47. Yesterday they were right for awhile, then I got logged out (happens alot at work) and when I logged back in, they were wrong again.
Postby GR-8 » Thu Mar 13, 2008 9:14
I take my fixes back now. For good. I too have this flip flopping problem Tom speaks of.
LM
Postby LM » Thu Mar 13, 2008 9:14
FYI - we are looking into this... B)
Postby MazdaTom » Thu Mar 13, 2008 9:14
I turned off my "automatically detect DST" option and then manually selected "DST is in effect" option. Haven't noticed anything out of whack since then.
LM
hummmm....that's good to know. Thnx Tom.
Postby tsx_guy » Thu Mar 13, 2008 9:14
i tried tom's fix and all is well...for me...in regards to the TZ issue on the boards...
LM
InvisionPower just uploaded a patch to fix this issue. Try using your previous settings and let me know if it is working ok.
Nope. Bumped it back an hour.
LM
Thanks Tom. Still trouble shooting...
I wouldn't worry too much about it.
Return to “Colorado Automotive Enthusiasts News and Info”
Users browsing this forum: No registered users and 4 guests
