Daylight Savings?
Maybe you'll have to change the settings for your profile. The times I see on the site are correct. Just verify you're using the correct time zone in your profile.
You can check this by going to "My Control Panel", Down on the left, under options , there's "board settings". At the top, it lists the time zone, and there's a checkbox to automatically adjust to DST.
<div class='quotetop'>QUOTE (Greek8 @ Mar 9 2008, 05:09 PM) [url=index.php?act=findpost&pid=31048]<{POST_SNAPBACK}>[/url]</div>
I have an Update on my quick fix. As I just found out it is a temporary fix. If most of you are like me and have CMZC set as a home page the real fix should be to make sure your settings are correct as Huzer (Tim) pointed out in the second post. When that is done log out and log back in. Your time will be correct. Now the next step to permanantly fix this is to reset the Club page as your home page. This will reset the refreshed settings.
Quick fix for this is to log out and log back in if all your settings are correct and time is still wrong.[/b]
My settings flip-flop back and forth. Right now it says it's 6:47 am, but it's actually 7:47. Yesterday they were right for awhile, then I got logged out (happens alot at work) and when I logged back in, they were wrong again.
LM
Return to “Colorado Automotive Enthusiasts News and Info”
