Got the codes ran. A random misfire and coolant level but no leaks so nothing ridiculously bad. Anyways it still dies at idle but Greddy said a BOV will solve that and here are the graphs we pulled from three runs. One very easy, one normal, and one hard:
http://coloradomazdaclub.com/forums/upload..._108_550410.jpg
http://coloradomazdaclub.com/forums/upload..._108_777823.jpg
http://coloradomazdaclub.com/forums/upload...108_1258213.jpg
Datalogs
For the ten thousand time I have to get the BOV installed to stop the dying at idle problem.
Mods:
Mods:
- RX-7drifter
<div class='quotetop'>QUOTE (SpeedRacer @ Mar 7 2008, 10:49 PM) [url=index.php?act=findpost&pid=30797]<{POST_SNAPBACK}>[/url]</div>
do you have a car?
No Ghost my question was There is CURRENTLY no BOV on your car? Just curious why you'd start the car without the BOV on a turbo setup..[/b]
do you have a car?
arctic_blue83
<div class='quotetop'>QUOTE (Greek8 @ Mar 7 2008, 10:05 PM) [url=index.php?act=findpost&pid=30785]<{POST_SNAPBACK}>[/url]</div>
Holy shit... for once, I agree.... Ghost, get a compression test man. After you cleared the codes, did they return?
The missfire could be to the motor not holding compresion. You really should get it checked.[/b]
No-Coast-Punk
<div class='quotetop'>QUOTE (Greek8 @ Mar 7 2008, 11:53 PM) [url=index.php?act=findpost&pid=30802]<{POST_SNAPBACK}>[/url]</div>
But yet Greddy says that installing one will cure the problem? Fishy.
according to greddy the boost is too low and doesn't require one.[/b]
The idle problem is actually gone. I rerouted the pressure sensor to the top of the intake manifold and it stopped reading pressure at idle. I'm installing the BOV now just for good measure. I believe the ECU was causing the problem with the pressure but it could have been any number of things.
Mods:
Mods:
So is it now running good?
Users browsing this forum: No registered users and 11 guests
