Datalogs
rx8ghost
Postby rx8ghost » Fri Mar 07, 2008 9:14
Got the codes ran. A random misfire and coolant level but no leaks so nothing ridiculously bad. Anyways it still dies at idle but Greddy said a BOV will solve that and here are the graphs we pulled from three runs. One very easy, one normal, and one hard:
http://coloradomazdaclub.com/forums/upload..._108_550410.jpg
http://coloradomazdaclub.com/forums/upload..._108_777823.jpg
http://coloradomazdaclub.com/forums/upload...108_1258213.jpg
Mods:
Postby SpeedRacer » Fri Mar 07, 2008 9:14
There's no BOV on ur car?
rx8ghost
For the ten thousand time I have to get the BOV installed to stop the dying at idle problem.
Mods:
RX-7drifter
Postby RX-7drifter » Fri Mar 07, 2008 9:14
the BOV we know is one problem that will be fixed soon
Postby GR-8 » Fri Mar 07, 2008 9:14
The missfire could be to the motor not holding compresion. You really should get it checked.
No Ghost my question was There is CURRENTLY no BOV on your car? Just curious why you'd start the car without the BOV on a turbo setup..
according to greddy the boost is too low and doesn't require one.
Postby tsx_guy » Fri Mar 07, 2008 9:14
<div class='quotetop'>QUOTE (SpeedRacer @ Mar 7 2008, 10:49 PM) [url=index.php?act=findpost&pid=30797]<{POST_SNAPBACK}>[/url]</div>
No Ghost my question was There is CURRENTLY no BOV on your car? Just curious why you'd start the car without the BOV on a turbo setup..[/b]
do you have a car?
Guido stop whoring. My question was legitimate
arctic_blue83
Postby arctic_blue83 » Sat Mar 08, 2008 9:14
<div class='quotetop'>QUOTE (Greek8 @ Mar 7 2008, 10:05 PM) [url=index.php?act=findpost&pid=30785]<{POST_SNAPBACK}>[/url]</div>
The missfire could be to the motor not holding compresion. You really should get it checked.[/b]
Holy shit... for once, I agree.... Ghost, get a compression test man. After you cleared the codes, did they return?
No-Coast-Punk
Postby No-Coast-Punk » Mon Mar 10, 2008 9:14
Why is Greddy saying the BOV is causing an idle problem? A BOV should do exactly 0 at idle.
Postby MazdaTom » Mon Mar 10, 2008 9:14
<div class='quotetop'>QUOTE (Greek8 @ Mar 7 2008, 11:53 PM) [url=index.php?act=findpost&pid=30802]<{POST_SNAPBACK}>[/url]</div>
according to greddy the boost is too low and doesn't require one.[/b]
But yet Greddy says that installing one will cure the problem? Fishy.
rx8ghost
Postby rx8ghost » Mon Mar 10, 2008 9:14
The idle problem is actually gone. I rerouted the pressure sensor to the top of the intake manifold and it stopped reading pressure at idle. I'm installing the BOV now just for good measure. I believe the ECU was causing the problem with the pressure but it could have been any number of things.
Mods:
Postby RX-7 Chris » Mon Mar 10, 2008 9:14
So is it now running good?
rx8ghost
It runs fine but I have to get the compression checked today after work.
Mods:
