RX8 Troubles
LM
<div class='quotetop'>QUOTE (Army RX8 @ Feb 21 2008, 07:24 PM) [url=index.php?act=findpost&pid=27237]<{POST_SNAPBACK}>[/url]</div>
That doesn't sound good. Have you tried disconnecting the battery again?
I just installed my K&N Typhoon Cold Air Intake. I had to undo the Neg Batt. Terminal as per the directions. Now my DSC light is flashing and my skid indicator is lit up while the car is idling. What goes??[/b]
Hrm... I dunno did you post this up on rx8club.com as well? PM Crazygreek and rx8 ghost they might know..
- Colombia28
No-Coast-Punk
<div class='quotetop'>QUOTE (No-Coast-Punk @ Feb 21 2008, 10:28 PM) [url=index.php?act=findpost&pid=27315]<{POST_SNAPBACK}>[/url]</div>
That sounds about right. I remember it turned on when I did my 6 disc changer swap. Just probably needs to reset itself.
Have you actually driven the car around the block? Sometimes the car needs to actually see all 4 wheel speed sensors turning to verify correct operation before it will turn the dummy light off.[/b]
that is good news.
- RX-7drifter
