RX8 Troubles
Army RX8
Postby Army RX8 » Thu Feb 21, 2008 9:14
I just installed my K&N Typhoon Cold Air Intake. I had to undo the Neg Batt. Terminal as per the directions. Now my DSC light is flashing and my skid indicator is lit up while the car is idling. What goes??
LM
Postby LM » Thu Feb 21, 2008 9:14
<div class='quotetop'>QUOTE (Army RX8 @ Feb 21 2008, 07:24 PM) [url=index.php?act=findpost&pid=27237]<{POST_SNAPBACK}>[/url]</div>
I just installed my K&N Typhoon Cold Air Intake. I had to undo the Neg Batt. Terminal as per the directions. Now my DSC light is flashing and my skid indicator is lit up while the car is idling. What goes??[/b]
That doesn't sound good. Have you tried disconnecting the battery again?
Postby SpeedRacer » Thu Feb 21, 2008 9:14
Hrm... I dunno did you post this up on rx8club.com as well? PM Crazygreek and rx8 ghost they might know..
Postby Colombia28 » Thu Feb 21, 2008 9:14
Maybe try resetting the ECU once more. Sounds like its not mechanical, so thats a good thing.
No-Coast-Punk
Postby No-Coast-Punk » Thu Feb 21, 2008 9:14
Have you actually driven the car around the block? Sometimes the car needs to actually see all 4 wheel speed sensors turning to verify correct operation before it will turn the dummy light off.
Thats a good point I forgot about that... That also happens when you dyno the car :P
Postby GR-8 » Thu Feb 21, 2008 9:14
<div class='quotetop'>QUOTE (No-Coast-Punk @ Feb 21 2008, 10:28 PM) [url=index.php?act=findpost&pid=27315]<{POST_SNAPBACK}>[/url]</div>
Have you actually driven the car around the block? Sometimes the car needs to actually see all 4 wheel speed sensors turning to verify correct operation before it will turn the dummy light off.[/b]
That sounds about right. I remember it turned on when I did my 6 disc changer swap. Just probably needs to reset itself.
rx8ghost
Postby rx8ghost » Thu Feb 21, 2008 9:14
Yep it'll do that for a couple of drives. Don't look to much into it.
Mods:
Postby Huzer21 » Fri Feb 22, 2008 9:14
There's a procedure in the manual to clear. Basically, you have to turn the car on, turn the wheel all the way to the left, then all the way to the right, Turn car off, start back up, and the lights will be cleared.
And no, I'm not joking.
Postby GR-8 » Fri Feb 22, 2008 9:14
That's true too. How could I forget that.
OpacRX
Postby OpacRX » Fri Feb 22, 2008 9:14
Yeah lol
Army RX8
Postby Army RX8 » Thu Feb 28, 2008 9:14
I finally got it fixed a couple days ago. I didnt get a manual when i bought the car so that kinda screwed me. I tried driving it that didnt work either. I unplugged the 2 fuses for the DSC, waited a couple minutes and plugged em back in. No problems after that. Thanks guys
Postby RX-7 Chris » Thu Feb 28, 2008 9:14
that is good news.
RX-7drifter
Postby RX-7drifter » Thu Feb 28, 2008 9:14
glad to hear it's fixed
Postby Huzer21 » Thu Feb 28, 2008 9:14
Did you try the other method? That's exactly what's stated in the manual, and what I've done 5 or 6 times after I've disconnected power.
If you don't have an owner's manual, you can download one here. Currently, they have 2004-2007.
