My new car!
jamiel
Postby jamiel » Sun Sep 11, 2011 9:14
chickenwafer wrote:I don't have a set of Easy Outs (doh!)
I have a few different sizes you're welcome to use- I'll be around today. what's the OD of the bolt?
2003 Protege5
91 Protege LX (sold)
90 626 (sold)
90 Protege DX (sold)
Postby chickenwafer » Sun Sep 11, 2011 9:14
Thanks Jamie, I will measure the bolt in a few...it had a 10mm head so it's rather small.
Postby chickenwafer » Sun Sep 18, 2011 9:14
I found a local machine shop here that can hot tank my irons and "jet tank" my aluminum housings so I'm pumped for that.
I'm 99% I'm going to attempt my own porting. Mazdatrix sells a how-to porting DVD I'll snag. To boost confidence I lined up the gaskets on the LIM and UIM and and port-matched them. Just finished the LIM-to-engine surface and I feel pretty good about the results. Will post pictures later.
So as long as I don't do anything stupid or crazy I should be good to go on doing my own porting. I think I'm going with the Pineapple Racing porting templates. I might get creative and extend the intake port timing a bit on the lower/entry edge to gain a little more overlap timing, but we'll see. That's also the danger area for puncturing into the water jacket.
Postby VRx8 » Sun Sep 18, 2011 9:14
You got a lot of nerves my friend. I was thinking about buying some busted irons to practice.
Postby speedjunkie » Sun Sep 18, 2011 9:14
Porting actually isn't that bad. As long as you take your time and don't get to impatient, AND as long as you know what you're doing, which I believe Dave does haha. You'll be fine Dave. Can't wait to see the results!
eliminster
Postby eliminster » Mon Sep 19, 2011 9:14
Just remember the more extreme the port the more it lopes at idle.
87 red rx7
running 13b re cosmo motor
03 yellow wrx
yes it is a stock color
00 black s10 zr2
Postby speedjunkie » Mon Sep 19, 2011 9:14
I miss my loping HAHA, turns out it was actually just the engine drowning in fuel from the oversized primaries LOL.
eliminster
well that makes it more pronounced too but if you go big enough with a street port it comes out also.
87 red rx7
03 yellow wrx
00 black s10 zr2
Postby speedjunkie » Tue Sep 20, 2011 9:14
That's what I mean. I thought it was because of the size of the port, then come to find out it was only because of my primaries being too big to tune out enough fuel :(. LOL
Postby chickenwafer » Tue Sep 20, 2011 9:14
eliminster wrote:Just remember the more extreme the port the more it lopes at idle.
Exactly, which is the sound I want, which is why I mentioned extending the intake power lower than the standard Pineapple template which will create more overlap.
It's overlap that gives you the BRAP BRAP
I want mine like that too haha.
Postby iani1.1 » Wed Sep 21, 2011 9:14
overlap also gives you more flamage.
xIceHoundx
Postby xIceHoundx » Wed Sep 21, 2011 9:14
Lol for the sake of not reading thru 48 pages on this topic what all you got done to your FD now chicken? I noticed on the first page you said you got water/meth, your system is delivered based on boost pressures right? I just picked up an aquamist HFS3v2 water/meth injection system with their RX7 summer its delivers based on fuel injector duty cycle I wanted mine to be very fine tuned.
heres kinda what im planning to do:
Fuel system:
CJ motorsport Stage 1 fuel system w/ injectors and fuel pressure regulator (1,050.00$)
CJ Motorsport twin fuel pump assembly(330.00$)
Walbro fuel pump (120.00$)
Ignition system:
HKS Twin Power Ignition system (380.00$)
HKS Twin Power Ignition system harness (40.00$)
NGK spark plug wires (70.00$)
Battery relocation kit (90.00$)
Cooling system:
Aquamist HFS3v2 water/methanol injection kit w/ RX7 summer (850.00$) - DONE
Full pulleys set (300.00$)
Samco cooling system hose kit (130.00$)
Exhaust system:
RX7Store Downpipe/Midpipe combo(200.00$)
Apexi N1 NxTi catback exhaust(820.00$)
OR
HKS Hi power exhaust(400.00$)
Turbo system:
RX7Store GT35R GTX turbo kit (3,100.00$)
RX7Store V-mount intercooler/radiator(1,200.00$)
Greddy BOV (330.00$)
Greddy BOV flanges(40.00$)
Greddy Elbow (140.00$)
Tial 44mm Wastegate(375.00$)
Drivetrain/Clutch system:
ACT strip/street clutch kit (630.00$)
ACT ProLite flywheel(265.00$)
Short shift kit (200.00$)
Engine Management system:
Haltech PS 1000 EMS (2000.00$)
GM 3 bar map sensor (90.00$)
Instrumentals:
AEM boost gauge (160.00$)
AEM AFR wideband gauge (215.00$)
AEM water temp gauge (160.00$)
AEM oil temp gauge (160.00$)
AEM oil pressure gauge (215.00$)
AEM fuel pressure gauge (215.00$)
Aquamist water/methanol gauge(comes with kit)
A-pillar dual gauge pod (35.00$)
Tripower dual gauge center pod (110.00$)
Suspension system:
Tien Super Drift coilovers (1,550.00$)
AtomicRex Racing Pillow Balls and PowerFlex polyurathane bushing set(1,200.00$) - DONE
Brake system:
Hawk HP+ brake pads (150.00$) - DONE
RX7Store complete slotted brake rotors (360.00$)
[color="Black"]SO [color="Red"]FRESH[/color][/color]
Postby VRx8 » Wed Sep 21, 2011 9:14
Got to love the Brap Brap, Dave just go with a bridge #### it lol
eliminster
Postby eliminster » Wed Sep 21, 2011 9:14
oh just so everyone knows I go to school at csu pueblo in the automotive industry managment program, i have access to everything our program has which might include in the near future a dyno and up to date alignment system.
87 red rx7
03 yellow wrx
00 black s10 zr2
Users browsing this forum: No registered users and 99 guests
