finally getting tuned today at mac
RichB
Postby RichB » Thu Nov 18, 2010 9:14
reconbygod12 wrote:so the ptp fix didnt work so hot on my car it stll smokes but i am going to try a oil catch can and see how it goes
I don't see how installing a pill in the breather port would help with a smoking turbo. It might help with PCV smoking, but it has nothing to do with the turbo.
I have seen people use an oil restricter screw for the oil return on the turbo. That option seems to work a little better. It is still masking the problem though, you might as well get the turbo fixed.
reconbygod12
Postby reconbygod12 » Thu Nov 18, 2010 9:14
yeah it smokes at idle and stop lights i do pretty much what soemone else does keep foot on gas around 1k rpms and i am fine..i dont boost as much and i turned my turbo down to 15psi, but i decided to go with teh bnr turbo when i get enough money
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
RichB
Postby RichB » Fri Nov 19, 2010 9:14
What stage BNR?
reconbygod12
Postby reconbygod12 » Fri Nov 19, 2010 9:14
im getting a bnr stage 2 or 3 havent decided
04 mazda 6s-gone
Postby erod550 » Fri Nov 19, 2010 9:14
RichB wrote:I don't see how installing a pill in the breather port would help with a smoking turbo. It might help with PCV smoking, but it has nothing to do with the turbo.
This is why the PCV fix helps a lot of the smoking turbo issues.
http://www.pt-performance.com/showProduct.php?vID=3&cID=4&pID=260
RichB
reconbygod12 wrote:im getting a bnr stage 2 or 3 havent decided
Might as well go with 3. Its $100 more.
RichB
erod550 wrote:This is why the PCV fix helps a lot of the smoking turbo issues.
Yea, I've seen that before. I'd think this would fix the problem of smoking when you release the gas after going WOT. Not when sitting at idle.
Postby erod550 » Sat Nov 20, 2010 9:14
The pressure difference and lack of vacuum happens at idle, which causes the oil to get past the seals and cause the smoke.
Users browsing this forum: No registered users and 136 guests
