finally getting tuned today at mac
reconbygod12
Postby reconbygod12 » Wed Nov 03, 2010 9:14
do you know the size of the pill, because they are bankrupt so i am not so sure about ordering from them
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
Postby movovr » Wed Nov 03, 2010 9:14
I do not. It appears to be custom machined.
Postby erod550 » Wed Nov 03, 2010 9:14
movovr wrote:The PTP pcv fix literally takes 5 minutes. You pull the line off the top right side of the crankcase, drop the "pill" in and tap with a mallet so it's snug. Put the line back on and your done.
Getting that line off is easier said than done. I wanted to take it off when I was doing my HPFP but couldn't get it. Or maybe I just wasn't doing it right.
You just have to very careful not to break off the clip on the inside.
reconbygod12
Postby reconbygod12 » Thu Nov 04, 2010 9:14
so i took my change ordering from ptp and i am tracking it and it already is registered that its in denver from thei rlocation in washington so we shall see if i actually get my mpart
04 mazda 6s-gone
reconbygod12
so the ptp fix didnt work so hot on my car it stll smokes but i am going to try a oil catch can and see how it goes
04 mazda 6s-gone
Postby tbot » Thu Nov 04, 2010 9:14
Ur turbo seals are ****ed from running catless and high boost...the sooner you accept that the sooner you'll be on the right track to fix it and not have a smoking car anymore.
reconbygod12
lol yeah pretty much is true i just dont wnat to accept it yet because it makes me sad
04 mazda 6s-gone
reconbygod12
so where can you order new turbo seals from or is this soemthing where i would have to order a whole new turbo?
04 mazda 6s-gone
whole new turbo
Postby ~Barn~ » Thu Nov 04, 2010 9:14
Can I buy your ptp from you?
EDIT: Nevermind... I just read that it's actually only needed for non-OE downpipes.
Image 720.935.6438
reconbygod12
im keepng my ptp, because i am still getting a new turbo. just have to convience the wife to let me spend 1800 on new garret
04 mazda 6s-gone
dsm_luck22
Postby dsm_luck22 » Tue Nov 16, 2010 9:14
My 09 smokes like a chimney at idle. I had the PTP pill, and banjo bolt, plus 5w-40. Nothing stops the torrent of smoke. It sucks but I am just going to get a BNR in there and be done with it. Oh well at least tax returns this year will soften the blow...
Postby erod550 » Wed Nov 17, 2010 9:14
When did your 09 start smoking? Do you have a catless downpipe? If so, was it fine for a while and then started smoking later on?
I've been catless and running 18psi for about 10-12k miles now and still no smoke at idle <knock on wood>.
dsm_luck22
Postby dsm_luck22 » Wed Nov 17, 2010 9:14
erod550 wrote:When did your 09 start smoking? Do you have a catless downpipe? If so, was it fine for a while and then started smoking later on?
Only exhaust mods are resonator deletes and a exhaust shop racepipe. Downpipe is stock. It has been smoking for about 6 months though but I found that if I keep the rpms above 1k at idle it wont smoke, so I usually do that manually at lights.
Users browsing this forum: Baidu [Spider] and 139 guests
