finally getting tuned today at mac
- reconbygod12
movovr wrote:The PTP pcv fix literally takes 5 minutes. You pull the line off the top right side of the crankcase, drop the "pill" in and tap with a mallet so it's snug. Put the line back on and your done.
Getting that line off is easier said than done. I wanted to take it off when I was doing my HPFP but couldn't get it. Or maybe I just wasn't doing it right.
- reconbygod12
- reconbygod12
- reconbygod12
- reconbygod12
Can I buy your ptp from you?
EDIT: Nevermind... I just read that it's actually only needed for non-OE downpipes.
- reconbygod12
dsm_luck22
When did your 09 start smoking? Do you have a catless downpipe? If so, was it fine for a while and then started smoking later on?
I've been catless and running 18psi for about 10-12k miles now and still no smoke at idle <knock on wood>.
dsm_luck22
erod550 wrote:When did your 09 start smoking? Do you have a catless downpipe? If so, was it fine for a while and then started smoking later on?
Only exhaust mods are resonator deletes and a exhaust shop racepipe. Downpipe is stock. It has been smoking for about 6 months though but I found that if I keep the rpms above 1k at idle it wont smoke, so I usually do that manually at lights.
Users browsing this forum: No registered users and 137 guests
