Cobb Accessport for MS6
Postby ~Barn~ » Wed Mar 11, 2009 9:14
MazdaTom wrote:^Go buy a GM product and enjoy yourself a Hypertech.
Ha! Tell me about it; I've done it!
Not to mention that, that Z28 would rape my Mazda! Image
Then again I'm not in my 20's anymore, and I don't use quite so much hair gel, so....
bobopud
Postby bobopud » Wed Mar 11, 2009 9:14
One of my deciding factors on the Cobb AP vs CPE Standback was the Cobb AP was $700. The CPE unit with both flashes and the PnP harness was more than double that.
To be fair though, you can currently tune with the CPE, with the Cobb you need to either pay for an etune or be stuck with one of the OTS maps for now.
Well at least they give you the option to use existing maps or have a a custom one done. I think that's a selling point. (?)
jeffms6
Postby jeffms6 » Thu Mar 12, 2009 9:14
bobopud wrote:Stretching the springs helps to ensure a better connection to the plug. Some people have said that it helps with engine studder others don't think it does anything, but it doesn't hurt anything and is very simple.
Did you use anti-seize on the plugs and/or dielectric grease on the connectors? I'm installing the Denso Iridium ITV22 plugs this weekend. I don't want to screw this up. My car is running great... I don't want to fxxx it up.
bobopud
Postby bobopud » Fri Mar 13, 2009 9:14
jeffms6 wrote:Did you use anti-seize on the plugs and/or dielectric grease on the connectors? I'm installing the Denso Iridium ITV22 plugs this weekend. I don't want to screw this up. My car is running great... I don't want to fxxx it up.
I used both when I installed my plugs. Just make sure to remove the excess, the anti seize I got is made by the same people that make PB Blaster and that stuff can go everywhere if you're not careful.
bobopud
BTW, where in St. Louis are you Jeff? I am in Baldwin about 3 times a year. My company headquarters are out there. I think I am one of the few that like that city, most of it anyway.
jeffms6
Postby jeffms6 » Fri Mar 13, 2009 9:14
I'm in Chesterfield only 15 minutes from Ballwin. Let me know the next time you are going to be in town. I'd like to get your opinion on my current mods.
Rich
Postby Rich » Fri Mar 13, 2009 9:14
If my Standback isn't good when I get it back from CP-E, I'm going AP.
bobopud
Postby bobopud » Sat Mar 14, 2009 9:14
jeffms6 wrote:I'm in Chesterfield only 15 minutes from Ballwin. Let me know the next time you are going to be in town. I'd like to get your opinion on my current mods.
I think the hotel I stay in is in Chesterfield. I usually stay at the giant Drury Inn. It is a ways from the office, but they have free drinks nightly.
I just got done with a recent trip out there. I usually have to go out there to put out some big huge forest fire that turns out to just be some small dumpster fire. For the next couple of months I'll be traveling to Dallas a lot. I wish I could take my car with me so I could get a Cobb Tune at their Plano Facility.
bobopud
Rich wrote:If my Standback isn't good when I get it back from CP-E, I'm going AP.
What's wrong with the Standback?
firestoned
Postby firestoned » Sat Mar 14, 2009 9:14
TRADER:3039183a: if the standback isnt fixed, then something else is wrong with your car. Why would the AP make any difference
Rich
Postby Rich » Sat Mar 14, 2009 9:14
It's simple logic. With the PnP harness installed, the car runs fine. With the Standback installed, the car doesn't run fine.....fuel cut, uncontrolled boosting, etc. That leaves the Standback as the culprit. I have the fuel cut flash, a CP-E fuel pump, a working wastegate and wastegate solenoid. I am overboosting on just my ECU, but that is expected with a full TB exhaust w/ no back pressure. It's a spike only, not boost creep. So, still say I'm a TRAITOR? :)
firestoned
Rich wrote:It's simple logic. With the PnP harness installed, the car runs fine. With the Standback installed, the car doesn't run fine.....fuel cut, uncontrolled boosting, etc. That leaves the Standback as the culprit. I have the fuel cut flash, a CP-E fuel pump, a working wastegate and wastegate solenoid. I am overboosting on just my ECU, but that is expected with a full TB exhaust w/ no back pressure. It's a spike only, not boost creep. So, still say I'm a TRAITOR? :)
i agree, its simple logic. The standback must be messed up, you said you were getting it fixed. If it comes back, and the same thing happens, then it is NOT the Standback..
Overboost may be normal, but certainly not 18-19psi like you have. :)
Rich
I agree with you as well. I am fairly certain the Standback will behave once installed this Monday. It was flashed with the newest firmware, and a new map switch was installed. If for some reason it doesn't work, Jordan thinks it may be a connector issue with my factory harness.
Regardless, you can't blame me for trying something different via an OBD2 port. Maybe I'll buy Patrick a case of beer to let me try his out for a day :)
bobopud
Rich wrote:I agree with you as well. I am fairly certain the Standback will behave once installed this Monday. It was flashed with the newest firmware, and a new map switch was installed. If for some reason it doesn't work, Jordan thinks it may be a connector issue with my factory harness.
We can coordinate something if the standback doesn't work out. I'll be spending 4 of the next 8 weeks in Texas, so you could use the AP during one of those weeks. It takes a couple of days for your LTFT's to settle down, until then you'd have to take it pretty easy.
