Cutting springs??
Postby VRx8 » Sun Mar 21, 2010 9:14
if i was u, i would buy another set of stock springs just in case and then go for it.
rush24
Postby rush24 » Mon Mar 22, 2010 9:14
VRx8 wrote:if i was u, i would buy another set of stock springs just in case and then go for it.
My plan is to cut the aftermarket Pedders springs and keep the stock ones just in case....:D
2007 Black CX7
Apexcone Raptor 6000k HID...
3" DP back Exhaust System
SURE Motor Mount...
[/color]
memphis
Postby memphis » Mon Mar 22, 2010 9:14
well if your truely not happy with how the after market springs are,, then ya.. cut them.. Atleast you will have your factory springs to put back on when you sell the car.
rush24
memphis wrote:well if your truely not happy with how the after market springs are,, then ya.. cut them.. Atleast you will have your factory springs to put back on when you sell the car.
That's what I plan on doing....:) I understand that everyone says that it's not a good idea....but I have the stock springs and I can always replace the aftermarket set....So here's to hopefully not throwing a few hundred $$ down the drain....:279129bf:
2007 Black CX7
SURE Motor Mount...
[/color]
memphis
I would just suggest that you take the time to do it right and make sure you cut the same amount on each spring.. Its best to get it right and go slow then to F something up in your other components of your suspension..
rush24
Definitely.....this is a project I will make sure I take my time on and get it right....Measure twice.....cut once....hahahahaha
2007 Black CX7
SURE Motor Mount...
[/color]
memphis
how much did those springs cost you? Is it the only springs on the market?
Postby erod550 » Mon Mar 22, 2010 9:14
There are some Vogtland springs that are supposed to lower 1.6". How much of a drop are you looking for? Very few springs go more than that. I think the Eibach sportlines on some cars can give a 2" drop, but generally to go lower than 1.5-1.6" you need coilovers.
rush24
erod550 wrote:There are some Vogtland springs that are supposed to lower 1.6". How much of a drop are you looking for? Very few springs go more than that. I think the Eibach sportlines on some cars can give a 2" drop, but generally to go lower than 1.5-1.6" you need coilovers.
The Vogtlands drop are about the same as the Pedders...between 1.25"-1.4" after they settle...I'm wanting a 1.75"+ drop...There is not an Eibach kit out yet for the CX-7....Most springs on the market for my car are about a 30mm to 40mm drop....
2007 Black CX7
SURE Motor Mount...
[/color]
This site says they are 1.6" (40mm). But vendors don't always provide correct info for their products.
http://www.vogtlandsuspension.com/p1079/Mazda-CX7-07---Lowering-Springs-958008/product_info.html
rush24
erod550 wrote:This site says they are 1.6" (40mm). But vendors don't always provide correct info for their products.
We'll see...There is a guy on a CX-7 forum that bought some of these...but hasn't really said what the drop is....or how it looks...
If cutting them doesn't work out....then I have a few options at least.....I just wish BC would come out with the Coilover kit already....That would solve the problem...:)
2007 Black CX7
SURE Motor Mount...
[/color]
Users browsing this forum: No registered users and 5 guests
