carson auto shop
T-time
carson auto shop
Postby T-time » Fri Feb 05, 2010 9:14
ill be there till 8 tonight and all day tomorrow, if you have access and would like to help me with my turbo install i would appreciate it,
i really need help with the gauge installs
deepSpeedMS3
Postby deepSpeedMS3 » Fri Feb 05, 2010 9:14
T-time wrote:ill be there till 8 tonight and all day tomorrow, if you have access and would like to help me with my turbo install i would appreciate it,
do you need to be military to get on base?
B) deepSpeed MS3 B)
Dange
Postby Dange » Fri Feb 05, 2010 9:14
naw you dont, you just have to show liscence registration insurance and come through gate one
t-time hey give me a call tomarrow morning i gotta come down and install a few bits myself so i can help out
04MSMGT
deepSpeedMS3
i may show up tommorrow to...PM me with directions and what not
B) deepSpeed MS3 B)
Postby VRx8 » Fri Feb 05, 2010 9:14
i think i can stop by, after i put my new corvette coils on the RX8
waldo
help
Postby waldo » Fri Feb 05, 2010 9:14
Never been a turbo guy always supercharge V-8's but I could probably be a pair of hands for you. I want to learn so stuff before I turbo my RX-8. Of course after I get back from my deployment
T-time
deep speed, you really wanna drive down from aurora? im greatfull
so heres where im at, i re-routed the coolant hoses, removed the hose bracket, i have the exhaust manifold dangling from the car
idk the rules the autoshop has, i know you have to have a shop card to bring a car in but idk about having someone help you out. i dont think they care.
on sat and sun they are open from 9-430, so ill be there at 9, if anyone wants to help out come thru gate 1 (if your not military), make sure you have license and registration and insurance that is valid otherwise you will get arrested. and call me at 862-812-9736
i would appreciate any help, i would like to get everything installed and wired tm so i can roll it out and tune it
T-time
oh and also i hate wiring (i can do it but it scares me) and i have to open the dash to wire the gauges
Dange
most the times ive been there ive had someone come help that didn't have a shop card. they dont really care about the rules there as long as you dont act retarded, technically your not supposed to install anything aftemarket on your car there, but ive done plenty of that... including getting help from the hobbyshop employees to install a catless downpipe.
ill be there installing the guages, boost controller and o2 modifier tomarrow ill try and get up at 7am so i can stop by advance autoparts and get some wiring goodies... i really need some vampire clips
04MSMGT
T-time
Postby T-time » Sat Feb 06, 2010 9:14
My shift cables are in the way.
T-time
Frank (pxrdrift) came down and helped me out a ton today, we got the downpipe on, the intake elbow on and the wastegate all bolted up, oh and the intercooler mounted. tm i have to do the piping, gauges (fml), and the pcm
PXRdriFT
Postby PXRdriFT » Sat Feb 06, 2010 9:14
Glad to help. Hopefully you can get things buttoned up tomorrow.
deepSpeedMS3
Postby deepSpeedMS3 » Sat Feb 06, 2010 9:14
PXRdriFT wrote:Glad to help. Hopefully you can get things buttoned up tomorrow.
Sorry i couldnt make it...i was in monument this weekend and had to help my parents with something before i could make it...maybe next time
B) deepSpeed MS3 B)
Dange
Postby Dange » Sun Feb 07, 2010 9:14
see the guages werent that bad. tomorrow evening we can do some tuning and datalogging and get your dash put back together.
04MSMGT
T-time
Postby T-time » Sun Feb 07, 2010 9:14
umm yea, i dont think were tuning anything. my computer crashes whenever i use it. i need a laptop with a serial port, plus the map input is reading a constant 31 psi so i think its not working and the tps input isnt working.... tm we can verify all the connections to the ecu, wire that a/f gauge correctly and tidy anything up. i need to make a post looking for a tuning shop in the springs. (btw the base map is there, but its not working because the inputs arent working)
Users browsing this forum: No registered users and 229 guests
